Mounting Challenger to Auto Rotisserie
#126517
09/26/08 02:59 PM
09/26/08 02:59 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
I am finally going to get to work on the body of my R/T over the winter. I picked up an auto rotisserie and the unibody brackets for mounting the car to it. I can see how they work for attaching to the rear bumper bracket bolt holes, but I'm not sure how to mount the front of the car. Should I just drill holes in the front arms of the rotisserie or is there another bracket that I am missing? It is an Auto Twirler rotisserie.
Sorry, I don't have any pics I can use at the moment.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Mounting Challenger to Auto Rotisserie
[Re: cataclysm80]
#126521
09/29/08 09:55 AM
09/29/08 09:55 AM
Erik
Stroudsburg, PA
Thanks. Those pics help. Yes, it will be on a level surface before I mount it.
[Re: Erik]
#126522
09/30/08 11:57 AM
09/30/08 11:57 AM
Erik
Stroudsburg, PA
From the pics, it looks like each arm of the rotisserie is only attached to the body by 1 bolt. Wouldn't that cause problems with movement of the body when you turn it over? How is the center of gravity with the arms in the positions pictured?
[Re: Erik]
#126523
09/30/08 02:10 PM
09/30/08 02:10 PM
Challenger 1
Cincinnati, Ohio
I'm not recomending 1 bolt in front, but that's how I've done it on two different cars with no problem. It's because I am too lazy and always in a hurry to make a plate that would catch both bumper bolt holes. It never moved and I transported the car twice and have spun the car round and round. Also making a plate I figured would change the center of gravity and you know we all don't like change if it's working. So I left it like is and mounted up the second car. I also did'nt want to modifiey it any more than necessary so I keep my opitions open for other cars without buying more arms from Auto Twirler.
BTW I don't feel the rear bumper bracket bolt holes are strong enough to bolt too, that's why I bolted up the rear spring hanger hole.
[Re: Challenger 1]
#126524
09/30/08 03:13 PM
09/30/08 03:13 PM
Erik
Stroudsburg, PA
Are the small brackets you used for the rear mounnting welded to the arms or bolted?
[Re: Erik]
#126525
09/30/08 04:14 PM
09/30/08 04:14 PM
Challenger 1
Cincinnati, Ohio
Bolted...2 5/16" bolts with 1/2-13 bolt going through the frame. I did this one nite when I first got this rotisserie and did not have a welder at home. It never gave me any trouble so I left it like it was and spent my time on the car.
[Re: Erik]
#126526
09/30/08 04:15 PM
09/30/08 04:15 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Mines like above with two holes and use the rear bumper bolt holes with no problem. I want put any more weight on them than the body panels, fenders, doors, trunk lid, etc...
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#126527
09/30/08 05:47 PM
09/30/08 05:47 PM
Challenger 1
Cincinnati, Ohio
I pretty much put mine back togeather on the spit, so it was plenty strong. When it came time for the rear springs and axle is when I took it off. It made it easier to slightly tilt the car one way or another when doing stuff.
