Big block clutch fan #1265142
07/10/12 12:11 PM
07/10/12 12:11 PM
new york
lilmoose102 Offline OP
new york
I have a 70 roadrunner,440,4 speed,22 inch radiator,with a shroud.I want to put a clutch fan on it,bought one from Mancini Racing at Carlisle,and it doesn"t fit.I looked up a mopar performance one at a local dealer and the measurements only allow a 1/4 of an inch between the fan clutch and radiator,not enough in my opinion.Any body else encounter this problem or have any suggestions? thanks.
Re: Big block clutch fan [Re: lilmoose102] #1265143
07/10/12 12:30 PM
07/10/12 12:30 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
The mounting block that is pressed onto the water pump shaft can be set at different depths, obviously yours is out too far. You may need to play around with it a bit but you should be able to mount that fan w no issues.
Re: Big block clutch fan [Re: Montclaire] #1265144
07/10/12 01:05 PM
07/10/12 01:05 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
91 Jag clutch from NAPA. Somebody else might remember the part numbr or exact model. I used it before and it is the shortest I could find.
I want my fair share
Re: Big block clutch fan [Re: lilmoose102] #1265145
07/10/12 01:18 PM
07/10/12 01:18 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
If you use a Hayden 2706 instead of a 2707 you'll save .3 inches in radiator clearance. More research available here:
http://www.haydenauto.com/upload/HaydenAuto/Documents/Cat_Hayden/2007-hayden-fan-clutch.pdf
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Big block clutch fan [Re: 3hundred] #1265146
07/10/12 01:39 PM
07/10/12 01:39 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Also, I would say that the relationship of the fan blade to the shroud is more important than the clutch face to the radiator (if greater than 1/4 inch, less is a big deal as the engine will rock on the mounts, esp with a stick). Seating the fan at the proper distance in relation to the shroud opening will help to guarantee good air flow.
Re: Big block clutch fan [Re: lilmoose102] #1265147
07/10/12 01:41 PM
07/10/12 01:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Why so tight???
OEM rad???
Re: Big block clutch fan [Re: RSNOMO] #1265148
07/10/12 01:45 PM
07/10/12 01:45 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Why so tight???
OEM rad???
It's a 4spd car, so the mount is way out there, probably has the deep water pump pulley on it. He'll need to press the mount closer to the pump and maybe use an AC pulley or just jog what he has a bit to get it to work. No reason it shouldn't though, it just will take a little longer than he thought it might. How deep is the stock spacer that you took off, if you did?
Re: Big block clutch fan [Re: RSNOMO] #1265149
07/10/12 01:48 PM
07/10/12 01:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I "think" the 2765 is shorter still.
You also might be able to heat the saddles and move the radiator core forward by about .50".
Someone also posted a mopar PN that was for a 69 A body w/340 and A/C.
Re: Big block clutch fan [Re: 64Post] #1265150
07/10/12 01:52 PM
07/10/12 01:52 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I guess I'd have to see the components at work here...
Got a three-core in front of a 7-blade A/C fan with viscous...
Plenty of clearance...
Re: Big block clutch fan [Re: RSNOMO] #1265151
07/10/12 01:54 PM
07/10/12 01:54 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Why are you making him waste money on another clutch? What you have should work fine, just fix it. This is the mopar kit, correct?
Re: Big block clutch fan [Re: lilmoose102] #1265152
07/10/12 03:44 PM
07/10/12 03:44 PM
new york
new york
Thanks for all the input.It is a oem radiator,car was originally 383.automatic,don"t know if that matters.the car starts to heat up in traffic,at long as its cruising along its runs around 170-175,
Re: Big block clutch fan [Re: Montclaire] #1265153
07/10/12 04:30 PM
07/10/12 04:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If this were the case then he would have an issue I would think with BELT ALIGNMENT ...
Re: Big block clutch fan [Re: JohnRR] #1265154
07/10/12 04:40 PM
07/10/12 04:40 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Yes and no. He hasn't posted any pics, so it's hard to comment further, but a simple tweak on the press and maybe a wp pulley swap and he should be fine, but if it's the mopar fan there is no reason for it not to work. A lot can change on a car in 40+ years. The flat AC pulley should pick up a ton of room for you and they're easy to find.
Re: Big block clutch fan [Re: 64Post] #1265155
07/11/12 10:04 AM
07/11/12 10:04 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
The aftermarket fan clutch IS 2765 made by Hayden. If you call the Mopar tech line they will even give you this number as they know their kit has the wrong height clutch. Call me if you have any questions on this.
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
1.715.842.3352
www.restorationradiators.com
Re: Big block clutch fan [Re: Montclaire] #1265156
07/11/12 10:09 AM
07/11/12 10:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If I'm reading this right he CHANGED the fan assembly off something that has been running for sometime , he makes no mention of belt alignment issues, so I don't even think that is an issue here.
Bob , MP has the wrong height unit in their kits and they KNOW it ... why do they still sell it then ????
Zippy, WTF ???? When is MP going to stop pushing GARBAGE on loyal customers ???
Re: Big block clutch fan [Re: JohnRR] #1265157
07/11/12 11:19 AM
07/11/12 11:19 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not sure what you're going off about since the clutch in the P4120758 kit has NEVER fit a 68 to 70 b body big block car at any point in it's history. It has always been too long for that application, nothing has changed.
I tried it back in 1999 and it did not fit my car back then, and there is no reason to believe it will fit in 2012 either
In 1999 it was 3 and 1/4" long.
In 2012, it is still 3 and 1/4" long.
The clutch assy was originally sourced from a 6 cylinder van application, and was chosen for minimal HP loss....not based on cooling capability, and certainly not on the ability to fit any specific years or models.
Rich H.
Esse Quam Videri
Re: Big block clutch fan [Re: ZIPPY] #1265158
07/11/12 12:33 PM
07/11/12 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for the response Rich and telling us what the original source was, I have never used that kit but the thought has crossed my mind on it.
now I'll ask the really STUPID question , What did MP think people were going to use it in if the parts were sourced from a 6cly.VAN application ??? I have a 2002 MP catolog here , it's listed in the HEMI section, the Big block section , and the smallblock section all with the same part number of P4120758.
Description is as follows ...
Most 60's and early 70's factory-built MUSCLE CARS were equipped with viscous fans for cooling purposes. Engineers have determined through dyno-testing that this viscous fan is the best replacement package. It provides thermostatically-controlled cooling, includes a lightweight balanced fan and takes the least amount of horsepower from the engine. Offers up to 15 horsepower gain on typical high performance V8s.
Has the description changed because it sure sounds like they are marketing it toward a specific years and models.
Seems like the bean counters took over ... again ... lets clean out existing stock of obsolete parts and sell them ... with no warranty of fitment ... to those dumb enough to buy MP parts .
This isn't directed at you Rich and it's great that someone like you is available to give us the lowdown , but I'm having a hard time waving the MP flag , yes I do buy their parts and recommend them when they fit the need for others , when they keep pulling crap like this ...
Re: Big block clutch fan [Re: JohnRR] #1265159
07/11/12 12:49 PM
07/11/12 12:49 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I have been watching this post now for the past couple of days and have yet to have anyone who has responded here to validate if, "1/4 of an inch separation" between the clutch fan and the radiator core is an acceptable distance. I am having a similar situation with my build...383 non A/C with an aftermarket aluminum Champion/American radiator. I am using the Jaguar clutch from Napa as it has the shortest shaft length of any out there, a 7 blade MoPar fan, without a fan shroud at present. It would be nice if someone here could validate that that distance will work properly. A simple yes or no would suffice without all the additional rhetoric. Please try to stay on point...
Re: Big block clutch fan [Re: JohnRR] #1265160
07/11/12 01:11 PM
07/11/12 01:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It was chosen from that application....
....for minimal HP loss....
Per the fellow involved with setting up the part number, it was the clutch that slipped the most, and reduced dyno hp the least out of the huge pile of them that were tested.
Works fine on 71-up b bodies, e bodies, small block A bodies, and that's about all that I know of.
Rich H.
Esse Quam Videri
Re: Big block clutch fan [Re: CR8CRSHR] #1265161
07/11/12 02:55 PM
07/11/12 02:55 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
I designed and engineered fan & clutch products for several years. We typically used a design guideline of 1" for fan blade to radiator core clearance. You can likely get a way with a bit less. I would not recommend to run a fan with 1/4" clearance to anything in an engine compartment. Also, make sure you use a fan shroud with approximatley 1" tip clearance and 50% or so fan depth covered by the shroud. If you don't your cooling efficiency will be very poor.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
