440 509 cam max flash stall? #1264438
07/08/12 11:52 PM
07/08/12 11:52 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
If I can't get my rockers back so I can put in my 250/255 108 solid in my
440, the 509 has always been on my mind with stock type rockers
For now. My converter needs a restall and lennys getting the work
I havnt talked with him about the 509 but if you gave it the CR it wants
And gear etc. What could be the best track converter for it in my dart?
Let's assume 3500 race weight 300cfm heads pro parts 430s etc 4800?
My tci core is 9inch
74 dart sport 440 www.Csucarbs.com
Re: 440 509 cam max flash stall? [Re: shoebox] #1264439
07/08/12 11:53 PM
07/08/12 11:53 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
What heads?
Re: 440 509 cam max flash stall? [Re: shoebox] #1264440
07/08/12 11:55 PM
07/08/12 11:55 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I want a high 10 outta this thing my buddy karls scamp does it with
The 509 but it's a 496!
Re: 440 509 cam max flash stall? [Re: shoebox] #1264441
07/09/12 12:10 AM
07/09/12 12:10 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Ported stealth heads 280cfm at 500
Re: 440 509 cam max flash stall? [Re: shoebox] #1264442
07/09/12 12:17 AM
07/09/12 12:17 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
https://board.moparts.org/ubbthreads/show...e=0#Post7265866
Check out this thread for my combo....I had a 5200 stall Coan behind it and it worked well. I'm sure Lenny will hook you up.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 440 509 cam max flash stall? [Re: shoebox] #1264443
07/09/12 01:57 AM
07/09/12 01:57 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Hey Shoebox,
i started out with a 4200 behind my 440,509 cam.this was too tight.went to a 5200 - WAY better.this was with a 3.9 gear,went 4.1 even better.
i went a best of 11.12 at 3769llbs
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 440 509 cam max flash stall? [Re: tex013] #1264444
07/09/12 02:17 AM
07/09/12 02:17 AM
Renton Washington
Triple Threat Offline
Renton Washington
Don't be scared, I find most people run too tight of a converter.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 440 509 cam max flash stall? [Re: tex013] #1264445
07/09/12 02:31 AM
07/09/12 02:31 AM
california
dragduster71 Offline
california
tex in my post u said u went 11.70's with the 509 cam,now u run low 11's with it?
Re: 440 509 cam max flash stall? [Re: dragduster71] #1264446
07/09/12 03:38 AM
07/09/12 03:38 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Dart,
the 11.7,s was with 906 heads.
i now have stealth heads.took a little weight out,then put a dana in it - weight back in.Fitted better shocks and caltracs.New fuel system.
changed to a solid and have run 11.09
best with the 509 was 11.12
i think the heads may be maxed out in their current state or close to it.Car will mph high 119's but did a one off 121.3(with the 509)
Tex
New best MPH 130.32
Re: 440 509 cam max flash stall? [Re: tex013] #1264447
07/09/12 09:32 AM
07/09/12 09:32 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Good to hear it likes high stall! Get this piggy movin'
