6 pack outboard mixture screws #1264238
07/08/12 03:42 PM
07/08/12 03:42 PM
South San Francisco, Ca
70sixpkrt Offline OP
Do they still sell the tiny mixture screws for the outboard carbs? I am rebuilding a buddys carbs which were sitting for the last 10 years. The mixture screws were frozen and I would like to replace them. This is what the front bowl looked like.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 6 pack outboard mixture screws [Re: 70sixpkrt] #1264239
07/08/12 03:48 PM
07/08/12 03:48 PM
Another pic
4-speed
3:54 Dana
Re: 6 pack outboard mixture screws [Re: 70sixpkrt] #1264240
07/08/12 03:56 PM
07/08/12 03:56 PM
After pic.
4-speed
3:54 Dana
Re: 6 pack outboard mixture screws [Re: 70sixpkrt] #1264241
07/08/12 04:53 PM
07/08/12 04:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Maybe spray both sides with PB Blaster, let sit overnight. See if it loosens. If not, place it on a hot plate to warm it up.
Re: 6 pack outboard mixture screws [Re: RobX4406] #1264242
07/08/12 05:09 PM
07/08/12 05:09 PM
I got one out but the other ones head stripped. Do they still make these tiny mixture screws? They are smaller than a regular mixture screw.
4-speed
3:54 Dana
Re: 6 pack outboard mixture screws [Re: 70sixpkrt] #1264243
07/08/12 06:41 PM
07/08/12 06:41 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The first thing you need to do on any old 6pk carb that has tight screws is get the old cork seal out.It gets rock hard from age and first thing that happens is off comes one side of the screw head.Probably 75% of the carbs I get for restoration have at least two broken screws.I made a drill pilot that enables me to drill the screw on center,have a four sided pin punch,tap into hole,heat base around screw and 99% have came out.If you drill without a pilot and get off center you can plan on scrapping the base.
You can get the screws from Chicago Corvette Supply for less $$ than from Holley.Part # M1513.
http://chicagocorvette.net/
If you only need one,PM me and I'll put one in the mail.
Re: 6 pack outboard mixture screws [Re: 62maxwgn] #1264244
07/08/12 07:21 PM
07/08/12 07:21 PM
Thanks for the info. I'm going to a reputable carb shop tomorrow and let them take out the screw. I just wanted to know if the screws are still available. Thanks.
4-speed
3:54 Dana
Re: 6 pack outboard mixture screws [Re: 70sixpkrt] #1264245
07/09/12 11:39 AM
07/09/12 11:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Can't you just buy that assmebly? I know you can buy the carbs for $325-350 at Auto-Zone. That thing looked toasted..you must have worked on it for a long time to get it looking that good. I would have tossed it in the trash.
Coming soon!!!!
Re: 6 pack outboard mixture screws [Re: Mr.Yuck] #1264246
07/09/12 11:54 AM
07/09/12 11:54 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Stripped base is around $100.
These were worse than the above when I got them.
Re: 6 pack outboard mixture screws [Re: 62maxwgn] #1264247
07/09/12 01:21 PM
07/09/12 01:21 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
69sixpackbee sells a custom socket head style screw along with a ball end type allen wrench tool so you can adjust and tune without removing the carbs.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 6 pack outboard mixture screws [Re: 6PKRTSE] #1264248
07/09/12 04:21 PM
07/09/12 04:21 PM
62maxwgn thank you. His v code 4 speed roadrunner has been sitting for the last 10 yrs. I finally talked him into getting back into the car. He just wants to get the car running and then he is probably going to get a new set of carbs. These are not the original carbs. He bought these back in 1984 from six pack perf. I hate to see what the gas tank looks like inside. He is probably going to buy a new tank as well.
4-speed
3:54 Dana
