Re: 6 pack outboard mixture screws
[Re: 70sixpkrt]
#1264243
07/08/12 06:41 PM
07/08/12 06:41 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The first thing you need to do on any old 6pk carb that has tight screws is get the old cork seal out.It gets rock hard from age and first thing that happens is off comes one side of the screw head.Probably 75% of the carbs I get for restoration have at least two broken screws.I made a drill pilot that enables me to drill the screw on center,have a four sided pin punch,tap into hole,heat base around screw and 99% have came out.If you drill without a pilot and get off center you can plan on scrapping the base. You can get the screws from Chicago Corvette Supply for less $$ than from Holley.Part # M1513. http://chicagocorvette.net/If you only need one,PM me and I'll put one in the mail.
[Re: Mr.Yuck]
#1264246
07/09/12 11:54 AM
07/09/12 11:54 AM
62maxwgn
Blair County,PA
Can't you just buy that assmebly? I know you can buy the carbs for $325-350 at Auto-Zone. That thing looked toasted..you must have worked on it for a long time to get it looking that good. I would have tossed it in the trash.
Stripped base is around $100.
These were worse than the above when I got them.
[Re: 62maxwgn]
#1264247
07/09/12 01:21 PM
07/09/12 01:21 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
69sixpackbee sells a custom socket head style screw along with a ball end type allen wrench tool so you can adjust and tune without removing the carbs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
