Page 1 of 3 1 2 3
Aftermarket k-member questions #1263646
07/07/12 08:07 PM
07/07/12 08:07 PM
junction city oregon
V
viperblue72 Offline OP
V
Shopping for an aftermarket k-member for a duster. It is for my dad. I believe he wants coil over and rack and pinion. What is a good company and or any to avoid?
Re: Aftermarket k-member questions [Re: viperblue72] #1263647
07/07/12 08:11 PM
07/07/12 08:11 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
I only have had experience with the STR tubular K frame and it works perfect. There is a thread about it in here.
Re: Aftermarket k-member questions [Re: W9 Dart] #1263648
07/07/12 09:17 PM
07/07/12 09:17 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
CAP.... works for me, pro street roadrunner,purchased it when ray still owned the company, so i cant say how Qa-1 is doing these days ...purchased the full kit, coil overs ,rack n pinion...your spindles require modification which he did for my car, also need to fabricate an upper shock mount....make sure you find a competent alignment shop...fastest mph to date is 138.9...pefect(also heim joint upper and lowers)
Re: Aftermarket k-member questions [Re: pattyboy 572] #1263649
07/07/12 09:34 PM
07/07/12 09:34 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Alterkation is the best designed aftermarket k frame period. plus tons of options
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Aftermarket k-member questions [Re: bigtimeauto] #1263650
07/07/12 09:56 PM
07/07/12 09:56 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
To each is their own I guess... I'm just glad there are options.
Re: Aftermarket k-member questions [Re: bigtimeauto] #1263651
07/08/12 12:00 AM
07/08/12 12:00 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have to second that,the thing was 100% the best fitting and quality thing i bought for my car...i mean right down to amount of turns on a given nut! i love my alterkation and so do my boys who do chassis work!
Re: Aftermarket k-member questions [Re: fishy340] #1263652
07/08/12 12:11 AM
07/08/12 12:11 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
has anyone got any feedback or opinions on the one that jason from overkill race cars does?
Re: Aftermarket k-member questions [Re: Deepockets] #1263653
07/08/12 12:19 AM
07/08/12 12:19 AM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
I have talked to Jason about that kit.. He never finished it.
Re: Aftermarket k-member questions [Re: fishy340] #1263654
07/08/12 12:22 AM
07/08/12 12:22 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
with both posts!
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Aftermarket k-member questions [Re: MRMOPAR] #1263655
07/08/12 02:30 AM
07/08/12 02:30 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Alterkation here too. Easy to install.
Re: Aftermarket k-member questions [Re: viperblue72] #1263656
07/08/12 02:45 AM
07/08/12 02:45 AM
AndyF Offline
AndyF  Offline
I have an A-body alterk setup new in the box if you're interested.
Re: Aftermarket k-member questions [Re: MRMOPAR] #1263657
07/08/12 02:56 AM
07/08/12 02:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
with both posts!
Care to elaborate?
Re: Aftermarket k-member questions [Re: J_BODY] #1263658
07/08/12 01:05 PM
07/08/12 01:05 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
with both posts!
Care to elaborate?
Sure, even though i'm just a customer and not a company spokesman.
it is well engineered for all aspects of cars not just drag racing.
it fits perfectly
bump steer is spot on
ackerman is spot on
it can be had with torsion bars, coil overs, anti roll bars, whatever brake system fits your fancy.
Its built strong so i don't have to worry about it being weak or needing any extra bracing.
Is it heavier than some of the drag race only parts? maybe but i would rather loose weight somwhere other than the front suspension.
My car goes 175 smooth as glass.
No bump steer at all!
Re: Aftermarket k-member questions [Re: bigtimeauto] #1263659
07/08/12 01:22 PM
07/08/12 01:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
man that car rocks!
Mopar Performance
Re: Aftermarket k-member questions [Re: J_BODY] #1263660
07/08/12 03:33 PM
07/08/12 03:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
9.58 pass,even had time to lool down..lol car was never on scales,balanced or anything..put in and allighnedhttp://www.youtube.com/watch?v=mj-lGzUStao&feature=player_detailpage
Re: Aftermarket k-member questions *DELETED* [Re: fishy340] #1263661
07/08/12 03:33 PM
07/08/12 03:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Post deleted by fishy340
Re: Aftermarket k-member questions [Re: fishy340] #1263662
07/08/12 03:34 PM
07/08/12 03:34 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: Aftermarket k-member questions [Re: J_BODY] #1263663
07/08/12 04:12 PM
07/08/12 04:12 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
with both posts!
Care to elaborate?
Sure...
I have no financial interest in my response!
1. It bolts in place. Aside from removing some existing brackets (such as upper control arm bump stop - used a spot weld cutter and they were out).
2. No guessing on the install - the install instructions are well written. You can download them from the AlterK site.
3. Any questions - Bill answer's them right away.
4. I ran a bump steer plot using my laser toe gauge - needed no corrections.
5. Bill Reilly supplied a few additional parts that allowed me to use most of my MOPAR B Body Wilwood brake setup instead of buying a new kit.
6. Kit came with the Flaming River needle bearing U joints, and the one that goes on the bottom of the existing steering shaft is drilled with the correct size hole to pin it in place.
I've seen the AlterK on some other fast MOPARs, including Wes's Dart... Heard no complaints.
Compared to the other one I had - there is no comparison.
Re: Aftermarket k-member questions [Re: bigtimeauto] #1263664
07/08/12 04:27 PM
07/08/12 04:27 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
it fits perfectly
ackerman is spot on
X2.....and currently on my 2nd AlterKation setup. All-around best there is, especially for multi-purpose use.
Another option for a "race only" front end application is the Comp Chassis setup. I would not hesitate to run their front end as well.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Aftermarket k-member questions [Re: EvilB1Dart] #1263665
07/08/12 04:40 PM
07/08/12 04:40 PM
no mans land
racerbychoice Offline
no mans land
alterkation.......
myself, both my brothers and one cousin all use the alterKation frontend. it is on our street cars and race cars with thousands of miles on the street and 8/9/10-sec passes at the track without issue for many years. without question its the best front end on the market for mopars, period. dj
Page 1 of 3 1 2 3
