Re: Aftermarket k-member questions
[Re: W9 Dart]
#1263648
07/07/12 09:17 PM
07/07/12 09:17 PM
Posts: 452 new york usa
pattyboy 572
new york usa
CAP.... works for me, pro street roadrunner,purchased it when ray still owned the company, so i cant say how Qa-1 is doing these days ...purchased the full kit, coil overs ,rack n pinion...your spindles require modification which he did for my car, also need to fabricate an upper shock mount....make sure you find a competent alignment shop...fastest mph to date is 138.9...pefect(also heim joint upper and lowers)
[Re: bigtimeauto]
#1263650
07/07/12 09:56 PM
07/07/12 09:56 PM
Posts: 243 United States
W9 Dart
United States
Alterkation is the best designed aftermarket k frame period. plus tons of options
To each is their own I guess... I'm just glad there are options.
[Re: bigtimeauto]
#1263651
07/08/12 12:00 AM
07/08/12 12:00 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
i have to second that,the thing was 100% the best fitting and quality thing i bought for my car...i mean right down to amount of turns on a given nut! i love my alterkation and so do my boys who do chassis work!
[Re: MRMOPAR]
#1263657
07/08/12 02:56 AM
07/08/12 02:56 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
with both posts!
Care to elaborate?
[Re: J_BODY]
#1263658
07/08/12 01:05 PM
07/08/12 01:05 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
with both posts!
Care to elaborate?
Sure, even though i'm just a customer and not a company spokesman.
it is well engineered for all aspects of cars not just drag racing.
it fits perfectly bump steer is spot on ackerman is spot on it can be had with torsion bars, coil overs, anti roll bars, whatever brake system fits your fancy. Its built strong so i don't have to worry about it being weak or needing any extra bracing. Is it heavier than some of the drag race only parts? maybe but i would rather loose weight somwhere other than the front suspension.
My car goes 175 smooth as glass.
No bump steer at all!
BB, TT5,Procharged 3300lb Street Car 4.79/154
