"New" 77 w150 problems #1263464
07/07/12 01:06 PM
07/07/12 01:06 PM
Southern Indiana
R/T Lee Offline OP
R/T Lee  Offline OP
Southern Indiana
My brother just bought a 77 w150 (318/727/203). He had problems with the carburator, so after a rebuild we thought it would be ready. Someone left the key on overnight, and drained the battery( no biggie), after a 8 hr charge, we still had no power at all! No dash lights, headlights, dome lights or anything. We changed the starter relay, that looked pretty nasty, but still have no power. Any suggetions would be appreciated thanks.
NO!! It's not a Nova...
72' Demon 340-727-8 3/4 3.55
69' Charger 440-727-8 3/4
78 Powerwagon 318-727
99' Dakota R/T 5.9
74' Scamp (project)
96' Cherokee 4.0 4x4
Re: "New" 77 w150 problems [Re: R/T Lee] #1263465
07/07/12 01:14 PM
07/07/12 01:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Ma
Is the battery any good ?
Check the cables for internal corrosion
Bad fuseable links
Bad connections in the firewall connector
operator error
I am truckless..
Re: "New" 77 w150 problems [Re: 340SHORTY] #1263466
07/07/12 01:19 PM
07/07/12 01:19 PM
Southern Indiana
R/T Lee Offline OP
R/T Lee  Offline OP
Southern Indiana
He drove the truck home, just had carb issues. then the key was left on, and now we dont have any power. charged the battery and tested it, It is good.
99' Dakota R/T 5.9
74' Scamp (project)
Re: "New" 77 w150 problems [Re: R/T Lee] #1263467
07/07/12 01:31 PM
07/07/12 01:31 PM
Southern Indiana
R/T Lee Offline OP
R/T Lee  Offline OP
Southern Indiana
Only thing I can think It would be is a main fuse or fuseable link? Not sure exactly were it would be on the truck?
99' Dakota R/T 5.9
74' Scamp (project)
Re: "New" 77 w150 problems [Re: R/T Lee] #1263468
07/07/12 01:46 PM
07/07/12 01:46 PM
probably between the starter relay and the bulkhead but leaving the key on would not fry it. I'd start checking/cleaning terminals from the batt positive post toward the bulkhead then inside if needed to find the open
Re: "New" 77 w150 problems [Re: R/T Lee] #1263469
07/07/12 01:55 PM
07/07/12 01:55 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Ammeter is a thing to check also. Bypass is a good idea.
Re: "New" 77 w150 problems [Re: buildanother] #1263470
07/07/12 02:24 PM
07/07/12 02:24 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
All the recomendations sound good.
Being all power is suddenly lost, I would look at the fusable link first. It comes out of the firewall with all the other wires, then goes through another conector, to the starter slolenoid.
I have mechanical Aptitude.
I can screw up anything.
Re: "New" 77 w150 problems [Re: bboogieart] #1263471
07/07/12 07:34 PM
07/07/12 07:34 PM
Southern Indiana
R/T Lee Offline OP
R/T Lee  Offline OP
Southern Indiana
Thanks I'll check the fuseable link, that was my first thought buy wasnt sure where it was exactly. thnks for the pic!!
99' Dakota R/T 5.9
74' Scamp (project)
Re: "New" 77 w150 problems [Re: R/T Lee] #1263472
07/09/12 01:38 AM
07/09/12 01:38 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Check the ground from the battery to the body
Re: "New" 77 w150 problems [Re: BulletBob] #1263473
07/09/12 06:26 PM
07/09/12 06:26 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Fuse link would be my bet. Next bulk head connector. If not, check the plug on the ignition switch. They melt a lot of times.
Re: "New" 77 w150 problems [Re: R/T Lee] #1263474
07/09/12 07:29 PM
07/09/12 07:29 PM
Southern Indiana
R/T Lee Offline OP
R/T Lee  Offline OP
Southern Indiana
Got it running, it was a hot wire coming off the relay. One of the previous owners tried to do a repair or add something and made a poor connection. thanks for the input everybody.
99' Dakota R/T 5.9
74' Scamp (project)
