Question on Phenolic Carb Spacer #1263186
07/06/12 06:51 PM
07/06/12 06:51 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi all,
I am planning on replacing a 1" aluminum carb spacer with a phenolic carb spacer on my 1970 440 w/ a stock intake manifold and 750 CFM Edelbrock carb. I have a couple of questions for those out there who have done this:
1. Does a stock 440 manifold use the "open" or 4- hole spacer? I think it's open, but don't have access to the car for awhile to check it.
2. Any recommendations on one that works well on dissipating heat? I see Summit sells their own model and also carries an Edelbrock brand. Any preference?
Thanks much for your help!
Re: Question on Phenolic Carb Spacer [Re: dg_dodge] #1263187
07/06/12 06:54 PM
07/06/12 06:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Use a 4 hole spacer, pick whichever you want.
Re: Question on Phenolic Carb Spacer [Re: dg_dodge] #1263188
07/06/12 07:08 PM
07/06/12 07:08 PM
places
79powerwagon Offline
places
Edelbrock-Carter AFB's ONLY like the 4-holer. This per their own web site. This also from my own foolish experiences.
EDIT: The trick is to get the correct thickness spacer. Years ago at a swap meet, a vendor was selling 4 hole paper gaskets 1/4" thick. I bought 8 of them, and I use those to determine which thickness my particular engine needs by stacking them one at a time until I narrow it down. Three different engines, three different thicknesses.
Re: Question on Phenolic Carb Spacer [Re: dg_dodge] #1263189
07/06/12 07:13 PM
07/06/12 07:13 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I bought one off ebay (tho it's only 1/2"). Best price I could find. Link to the guy's ebay store is below.
Just get a 4 hole as advised, the 4 holes line up with the 4 butterflies on the carb. For my demon carb (big butterflies) I had to open up the holes a bit but it's easily done with sandpaper.
ebay link
Re: Question on Phenolic Carb Spacer [Re: Exit1965] #1263190
07/06/12 07:56 PM
07/06/12 07:56 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks a lot guys! I'm glad I checked here first!
Re: Question on Phenolic Carb Spacer [Re: dg_dodge] #1263191
07/06/12 11:32 PM
07/06/12 11:32 PM
The Carter carb, AFB or AVS intake manifolds(1969 and earlier) have the four holes, the later Holley carb. intakes(1970-71) have two elongated holes, one on each side of the intake divider The later Thermoquad intakes are another story altogether I would use the open on the hooley type intakes and the four hole on the Carter type intakes
Re: Question on Phenolic Carb Spacer [Re: Cab_Burge] #1263192
07/06/12 11:43 PM
07/06/12 11:43 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Look at shear plates also, you can get them insulated and they work wonders. Tim
Re: Question on Phenolic Carb Spacer [Re: astjp2] #1263193
07/07/12 01:51 AM
07/07/12 01:51 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Just make 1 out of wood, Hickory. Its a very hard wood. If you have a gasket you can make the spacer. Not hard to do and works great at insulating.
Re: Question on Phenolic Carb Spacer [Re: None2Slow] #1263194
07/07/12 09:32 AM
07/07/12 09:32 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Insulating is one thing, but I can vouch for idle/driveability improvements with the cheap 1/2" 4 hole spacer. There are many reports of increased low end with the 4 hole.
When I put it on, I think the carb was getting a better signal and I was able to close the butterflies quite a bit. My engine has always had issues with idling as it's a big cam in a low compression engine. That's the reason I went with the mighty demon because it had the adjustable idle-eze. Adding the 4 hole really helped for both heat and carb function in my case.
