Headrest Removal #1262975
07/06/12 02:05 PM
07/06/12 02:05 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
How do you remove the headrest from a 1970 A body with bench seats?? They adjust up and down but I can't get them too come out.
Howard
Re: Headrest Removal [Re: Howard] #1262976
07/06/12 06:53 PM
07/06/12 06:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
there should be a tab in the back. pull the headrest up unscrew the trim (i forget which side) and there will be a tab like thing you hold with a screwdriver which will disengage the latch.
Re: Headrest Removal [Re: mikemee1331] #1262977
07/06/12 06:56 PM
07/06/12 06:56 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Thanks,I'll give it a try
