Page 7 of 16 1 2 5 6 7 8 9 15 16
Re: Hemi vs Wedge [Re: Sixgun] #1262638
07/21/12 12:20 PM
07/21/12 12:20 PM
Texas
racer_amx Offline
racer_amx  Offline
Texas
Wedge hands down,for the simple fact that it makes similiar power to a hemi and its wayyy cheaper to build
Re: HEMI [Re: RUNCHARGER] #1262639
07/21/12 12:50 PM
07/21/12 12:50 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Actually did you ever read what Petty said after he drove the 426 Hemi for the first time in 63 or early 64? It was so much stronger than the wedges (like 10 or 15 MPH faster) he figured it had to be illegal.
Sheldon
I'm quite sure that "The King" , knew he was headed to major success, after running that first
race HEMI in NASCAR. But.. the wedges did "pave" the way for the HEMI.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: HEMI [Re: HYPER8oSoNic] #1262640
07/21/12 06:13 PM
07/21/12 06:13 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Mr. Petty went to the General because of the beginning of the 'Chrysler doldrums'...
Re: HEMI [Re: HYPER8oSoNic] #1262641
07/21/12 06:22 PM
07/21/12 06:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From I understand when the 426 Hemi first came out in 64 it did dominate NASCAR but in drag racing it was no faster then the wedge cars at first. So they did not drag race it right away as the Ramchargers worked with the Hemi and changed cams I believe to really wake it up for drag racing. The wedge really did not do to bad in NASCAR as I think Petty finished 3rd in points in 63 running the wedge. But the higher up wanted a guarantee to win Daytona in 64 and they did not feel the wedge could guarantee a win. So of course they adapted the Hemi heads to the reworked wedge block and did guarantee a win. It would have been cool if they had kept the Max Wedge in production also and update it over the years. I could see it now that along with the 383 , 440-6pk and Hemi you can also get a Max Wedge in the Roadrunner. Ron
Re: HEMI [Re: 383man] #1262642
07/21/12 07:58 PM
07/21/12 07:58 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
The initial problem in 64 was carburetion on the cross ram. The initial runs were with the same AFB's the wedge cars ran, and for some reason the AFB's did not work well on the Hemi. The mid 64 switch to the Holleys is what woke them up.
We've tried for years to make AFB's work on a Hemi crossram, and we never could. I don't know if it's the extremely big plenum or what it is, but we found the same thing. When Gary Conditt of the Ramchargers told me they never could, either, and that is why the mid year switch to Holleys, I didn't feel quite so stupid.
We run both Indy headed wedges, and a couple of Hemi cars. There ain't nothin' like a Hemi.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: HEMI [Re: 383man] #1262643
07/21/12 10:20 PM
07/21/12 10:20 PM
Desert Tracker
Desert Tracker
The first HEMIS in 64' did have tuning problems, not so much as the components they had, but getting them to work right. To tune a 426 Hemi like the 426
Max-Wedge would NOT work, simply because of each engines different "breathing" characteristics. It
took the talented hands and minds of Tom Hoover and other Ramcharger members and notable racers to bring the HEMI to a "user-friendly" status. AS they have done with the Max-Wedge engines. Yes Ron, it DEFINITELY would have been a very good option in the later years, if time and money allowed!!
Re: HEMI [Re: RSNOMO] #1262644
07/21/12 10:32 PM
07/21/12 10:32 PM
Desert Tracker
Desert Tracker
That could be putting things mildly, as Chryslers' rear-wheel drive cars were phased out by approx. 82', and the front-wheelers were coming by the truckload!
Re: Hemi vs Wedge [Re: Mr.Yuck] #1262645
07/21/12 11:54 PM
07/21/12 11:54 PM
tn
robnbird Offline
robnbird  Offline
tn
A wedge will work but a hemi is prettier. Hemi's used to be expensive so I understand why people drove wedges but today if you are building from new parts the cost is the same nearly to the penny. (If you want to go thru the price list item by item we will.) I will never figure out why someone would drive a wedge.
really? crank, rods, pistons, cam maybe but blocks, heads and valve train? no way. Hemi headers and intake are also more expensive. You'll spend 2x as much (maybe more) building a 600hp hemi vs wedge.
I have built both the 542ci 440-1/indy 542ci hemi/indy head. every part on both motors new. everything. And neither are 600hp closer to 900hp. the Hemi maby $1600. more. the wedge is a great way to go. but for me that little extra $1600, its HEMI all the way. I actually paid more for a set of headman hustlers for the 440-1' that I did for a set of tti' for the hemi.
Re: HEMI [Re: Steve1118] #1262646
07/22/12 12:30 AM
07/22/12 12:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You are correct as I forgot about switching to the Holley carbs. I had also read they changed the cam in the Hemi's from the one that was in it first. The Ramcharges figured out how to get the most out of the Hemi and the rest is history. Ron
Re: Hemi vs Wedge [Re: robnbird] #1262647
07/22/12 11:17 AM
07/22/12 11:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm not talking about a 900hp motor. I'm talking 6-700 local track bracket motor. Of course when you get up there w/ the wedge (or any motor) the cost jumps a ton.
Re: Hemi vs Wedge [Re: Mr.Yuck] #1262648
07/22/12 12:06 PM
07/22/12 12:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If the Hemi had been produced with 440 inches under it then no one would have ever accused it of haveing less TQ than the 440 wedge. Just like how the 426 wedge or max wedge is no comparison for the 426 hemi.
Re: Hemi vs Wedge [Re: HotRodDave] #1262649
07/22/12 01:10 PM
07/22/12 01:10 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I love the Street Hemi but I have often wondered if the factory had optimized the 69 A12 with Max Wedge heads with a matching camshaft and exhaust manifolds that thing would have been even more unreal on the streets, it probably would have been a turn key 12.5 car even with a bad driver. But that's not what happened.
Sheldon
Re: Hemi vs Wedge [Re: HotRodDave] #1262650
07/22/12 01:13 PM
07/22/12 01:13 PM
Desert Tracker
Desert Tracker
That may be a VERY GOOD observation, Dave! But, history does serve well, since Michigan bred "street racer/class racer" Jimmy Addison has proven that
theory with the famed "Silver Bullet" (67' 480+ cube HEMI powered GTX). And as for a comparision between the two types of 426 cube motors, again it depends on how quick you want to run. On the street, wedge motors are cheap to build and they do RUN HARD. But for the "upper" brackets and
class racing ("for the money"), the HEMI will get you the green and the respect ...all for a small
investment though. IMO, a BIG CUBE Maxie Wedge would be far MORE FUN to drive on the street and race at the track. Best of both worlds, and can do it on "pump gas"!! That is my
Re: Hemi vs Wedge [Re: Mr.Yuck] #1262651
07/22/12 01:45 PM
07/22/12 01:45 PM
Desert Tracker
Desert Tracker
From approx. 650-700 hp (RB motor) and up the induction/heads are good part of your money spent. Stronger bottom end components and race balanced rotating assembilies, drive up the cost, adding to the above, with a stock 440 block. For the ultimate strength and longevity, a aftermarket block is the way to go, maybe a little cheaper. Gets pretty pricey as you "dial in more "HP". But still cheaper than a HEMI, in the long run.
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262652
07/25/12 01:42 PM
07/25/12 01:42 PM
Jessie1 Offline
Jessie1  Offline
From my understanding, computer designed modifications, completed on a state of the art CNC head porting machine, are able to port a 906 cast iron head to flow similar to a stock 2780559/2468016 cast iron hemi head. 49 years ago, Chrysler achieved what is now achieveable with computers on a 906 head by adopting the Hemi head. No wonder they went the Hemi route.....
Sure, you can put free flowing aluminum heads on that wedge, but again, you can't compare aluminum heads on a wedge to aluminum heads on a Gen II Hemi.
The wedge is a great motor, but it's no Hemi. We may as well be debating a 383 Magnum vs. a 440 Magnum.....
Re: Hemi vs Wedge [Re: Jessie1] #1262653
07/27/12 06:05 PM
07/27/12 06:05 PM
Desert Tracker
Desert Tracker
You're right about the differences - "Wedge a great motor, but it's no HEMI". A Wedge is a wedge-headed motor and a HEMI is a Hemispherical-headed (meaning half-ball, or half-moon shaped chambers) motor. Nothing special between the two except the "top-end" pieces (carbs, heads valvetrain and camshaft). The blocks are different because of the HEMIS' hi-rpm, high torque output range, versus the WEDGES low to mid rpm, high torque output range. Just pick what range you want to run in - a HIGH-RPM screamer, or
a low-end "stump-pulling" super torque monster. Both EQUALLY run hard in their effective "ranges".
Re: Hemi vs Wedge [Re: HYPER8oSoNic] #1262654
07/27/12 11:32 PM
07/27/12 11:32 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
Go back a few pages and read my dyno figures on my 89.5 octane pumpgas Hemi. 818ftlbs.@4800. 852hp@ under 5900rpm. You can have your cake and eat it too.Dave
Re: Hemi vs Wedge [Re: quickd100] #1262655
07/28/12 03:23 AM
07/28/12 03:23 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Can't believe people are still "debating" this topic. The Hemi is better...Period...And its not even close..
MB
Re: Hemi vs Wedge [Re: quickd100] #1262656
07/28/12 09:46 AM
07/28/12 09:46 AM
Desert Tracker
Desert Tracker
Go back a few pages and read my dyno figures on my 89.5 octane pumpgas Hemi. [Email]818ftlbs.@4800.[/Email] 852hp@ under 5900rpm. You can have your cake and eat it too.Dave
Okay...again the debate over the better motor. Your dyno figures ARE impressive and I give you Kudos for achieving this feat on pump gas. But.. in reality this just tells me that you wanted to run a HEMI on pump gas for everyday use...midgrade gas at that!! The idea is very smart and IF the motor is efficient running at that octane level of gas.. then I'd say you DO have your cake and are eating it too!! BUT...how much did that cake COST!! Not everyone eats EXPENSIVE "cake", some of us love "pie" instead. Simple, inexpensive. easy-to-build, but very FULFILLING (performance wise)!!
A worth of "PIE":
www.popularhotrodding.com/enginemasters/articles/mopar/bigblock/
Titled: "The Big Wedge"
Built on the "smaller" Magnum platform!!
Impressive.
Re: Hemi vs Wedge [Re: HPMike] #1262657
07/28/12 09:58 AM
07/28/12 09:58 AM
Desert Tracker
Desert Tracker
MB
This debate may indeed go on forever,
Mike!! The HEMI may be the better engine in YOUR eyesight, BUT there are a LOT of WEDGE motor racers who say different. And they aren't backing off!! In fact, this thead may "eclipse" the ol' "413 vs. 440" thread.
