Re: HEMI
[Re: HYPER8oSoNic]
#1262641
07/21/12 06:22 PM
07/21/12 06:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
From I understand when the 426 Hemi first came out in 64 it did dominate NASCAR but in drag racing it was no faster then the wedge cars at first. So they did not drag race it right away as the Ramchargers worked with the Hemi and changed cams I believe to really wake it up for drag racing. The wedge really did not do to bad in NASCAR as I think Petty finished 3rd in points in 63 running the wedge. But the higher up wanted a guarantee to win Daytona in 64 and they did not feel the wedge could guarantee a win. So of course they adapted the Hemi heads to the reworked wedge block and did guarantee a win. It would have been cool if they had kept the Max Wedge in production also and update it over the years. I could see it now that along with the 383 , 440-6pk and Hemi you can also get a Max Wedge in the Roadrunner. Ron
Re: HEMI
[Re: 383man]
#1262642
07/21/12 07:58 PM
07/21/12 07:58 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
The initial problem in 64 was carburetion on the cross ram. The initial runs were with the same AFB's the wedge cars ran, and for some reason the AFB's did not work well on the Hemi. The mid 64 switch to the Holleys is what woke them up.
We've tried for years to make AFB's work on a Hemi crossram, and we never could. I don't know if it's the extremely big plenum or what it is, but we found the same thing. When Gary Conditt of the Ramchargers told me they never could, either, and that is why the mid year switch to Holleys, I didn't feel quite so stupid.
We run both Indy headed wedges, and a couple of Hemi cars. There ain't nothin' like a Hemi.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
Re: Hemi vs Wedge
[Re: Mr.Yuck]
#1262645
07/21/12 11:54 PM
07/21/12 11:54 PM
Posts: 914 tn
robnbird
tn
A wedge will work but a hemi is prettier. Hemi's used to be expensive so I understand why people drove wedges but today if you are building from new parts the cost is the same nearly to the penny. (If you want to go thru the price list item by item we will.) I will never figure out why someone would drive a wedge.
really? crank, rods, pistons, cam maybe but blocks, heads and valve train? no way. Hemi headers and intake are also more expensive. You'll spend 2x as much (maybe more) building a 600hp hemi vs wedge.
I have built both the 542ci 440-1/indy 542ci hemi/indy head. every part on both motors new. everything. And neither are 600hp closer to 900hp. the Hemi maby $1600. more. the wedge is a great way to go. but for me that little extra $1600, its HEMI all the way. I actually paid more for a set of headman hustlers for the 440-1' that I did for a set of tti' for the hemi.
Re: Hemi vs Wedge
[Re: robnbird]
#1262647
07/22/12 11:17 AM
07/22/12 11:17 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm not talking about a 900hp motor. I'm talking 6-700 local track bracket motor. Of course when you get up there w/ the wedge (or any motor) the cost jumps a ton.
Re: Hemi vs Wedge
[Re: Mr.Yuck]
#1262648
07/22/12 12:06 PM
07/22/12 12:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If the Hemi had been produced with 440 inches under it then no one would have ever accused it of haveing less TQ than the 440 wedge. Just like how the 426 wedge or max wedge is no comparison for the 426 hemi.
Re: Hemi vs Wedge
[Re: HotRodDave]
#1262650
07/22/12 01:13 PM
07/22/12 01:13 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
That may be a VERY GOOD observation, Dave! But, history does serve well, since Michigan bred "street racer/class racer" Jimmy Addison has proven that theory with the famed "Silver Bullet" (67' 480+ cube HEMI powered GTX). And as for a comparision between the two types of 426 cube motors, again it depends on how quick you want to run. On the street, wedge motors are cheap to build and they do RUN HARD. But for the "upper" brackets and class racing ("for the money"), the HEMI will get you the green and the respect ...all for a small investment though. IMO, a BIG CUBE Maxie Wedge would be far MORE FUN to drive on the street and race at the track. Best of both worlds, and can do it on "pump gas"!! That is my
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Hemi vs Wedge
[Re: Mr.Yuck]
#1262651
07/22/12 01:45 PM
07/22/12 01:45 PM
HYPER8oSoNic
Desert Tracker
From approx. 650-700 hp (RB motor) and up the induction/heads are good part of your money spent. Stronger bottom end components and race balanced rotating assembilies, drive up the cost, adding to the above, with a stock 440 block. For the ultimate strength and longevity, a aftermarket block is the way to go, maybe a little cheaper. Gets pretty pricey as you "dial in more "HP". But still cheaper than a HEMI, in the long run.
Re: Hemi vs Wedge
[Re: Jessie1]
#1262653
07/27/12 06:05 PM
07/27/12 06:05 PM
HYPER8oSoNic
Desert Tracker
From my understanding, computer designed modifications, completed on a state of the art CNC head porting machine, are able to port a 906 cast iron head to flow similar to a stock 2780559/2468016 cast iron hemi head. 49 years ago, Chrysler achieved what is now achieveable with computers on a 906 head by adopting the Hemi head. No wonder they went the Hemi route.....
Sure, you can put free flowing aluminum heads on that wedge, but again, you can't compare aluminum heads on a wedge to aluminum heads on a Gen II Hemi.
The wedge is a great motor, but it's no Hemi. We may as well be debating a 383 Magnum vs. a 440 Magnum.....
You're right about the differences - "Wedge a great motor, but it's no HEMI". A Wedge is a wedge-headed motor and a HEMI is a Hemispherical-headed (meaning half-ball, or half-moon shaped chambers) motor. Nothing special between the two except the "top-end" pieces (carbs, heads valvetrain and camshaft). The blocks are different because of the HEMIS' hi-rpm, high torque output range, versus the WEDGES low to mid rpm, high torque output range. Just pick what range you want to run in - a HIGH-RPM screamer, or a low-end "stump-pulling" super torque monster. Both EQUALLY run hard in their effective "ranges".
Re: Hemi vs Wedge
[Re: HYPER8oSoNic]
#1262654
07/27/12 11:32 PM
07/27/12 11:32 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Go back a few pages and read my dyno figures on my 89.5 octane pumpgas Hemi. 818ftlbs.@4800. 852hp@ under 5900rpm. You can have your cake and eat it too.Dave
