Swapping valve locks, do I need new retainers?
#1262091
07/05/12 12:11 PM
07/05/12 12:11 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I bought a set of 915s that had bigger valves installed, they are Milodon 3/8 shaft valves. I also got a set of take-off springs, locks, and retainers from a set of stealth heads. The locks are too small due to the upgraded valves, so I ordered a new set of 10' comp cams locks for 3/8 shafts. Do I need to order new retainers as well, or is the same retainer used across the board? The retainers are also from comp cams as part of the stealth package. Thanks
Re: Swapping valve locks, do I need new retainers?
[Re: Montclaire]
#1262094
07/05/12 01:05 PM
07/05/12 01:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
10* locks need 10* retainers...7* needs 7* and so forth. The only exception is Crane multi fit stuff.
RIP Monte Smith
[Re: CompWedgeEngines]
#1262095
07/05/12 01:07 PM
07/05/12 01:07 PM
Montclaire
Scranton, PA
Ok, so I should be able to tell if I have the right ones once I get to match them up. I looked at the 440 Source site quick before I had ordered and it looked like they had 10' retainers and locks but from what I am seeing now, it looks like the heads come with 7' and the 10's are an upgrade.
This begs the question, if I ordered the wrong locks, do I buy the 10' retainers, or return the locks and get 7' ones? Is a 7' lock and retainer UNDERkill for a 3/8th stem valve? This is a street motor only. Cam is a 509. Budget is a concern, but not at the risk of dropping a valve.
[Re: LaRoy Engines]
#1262098
07/05/12 11:20 PM
07/05/12 11:20 PM
Montclaire
Scranton, PA
Wait, why not? I have the springs, locks, and retainers off the stealths. I called Jegs and swapped my order, they are sending me the 7' comp locks for a 3/8ths valve to match my 7' stealth comp retainers. So the only difference is the locks, to match the bigger valve diameter. What am I missing?
[Re: Montclaire]
#1262099
07/06/12 11:40 AM
07/06/12 11:40 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
Because, the 440 Source retainers were designed for 11/32 stems, the hole in them isn't big enough for the 3/8 stem to fit properly. The valve tip will fit through but the tip and locks will stick way up above the retainer. I was pretty sure the 3/8 valves wouldn't work with the Stealth retainers so I called 440 Source BEFORE I posted.
You were advised poorly. Haven't you noticed? Too many people give advise here with NO DIRECT KNOWLEDGE of what they are talking about!
[Re: Montclaire]
#1262101
07/06/12 10:24 PM
07/06/12 10:24 PM
Montclaire
Scranton, PA
Looks like OD on the stealth springs is 1.550... 780-16?
[Re: Montclaire]
#1262102
07/06/12 10:30 PM
07/06/12 10:30 PM
CompWedgeEngines
Syracuse,NY
What we are trying to tell you is if you have 3/8 stem valves, you'll need valve locks that fit 3/8 valves ( wich sounds like you ordered) and retainers that are also for 3/8 valves. You cant swap 3/8 locks with 11/32 retainers. Right now it sounds like you have 3/8 locks ( 10* ?) and 3/8 valves, so you will need retainers for 3/8 valves that work with 10* locks. The only time this isnt the case, as I mentioned before, is with Crane multi fit products.
If you list what locks you bought, I can tell you what retainers you need. ( assuming you stuck with Stealth valves springs) Although its not 100% necessary, its always good to keep all products from 1 manufacter.
So, locks, retainers and valves all need to work together for the valve lock angle and the valve stem diameter.
RIP Monte Smith
#1262104
07/06/12 10:38 PM
07/06/12 10:38 PM
Posts: 5,875 communist bloc of new jersey
jamesc
that happens anywhere and everywhere but i don't see any evidence of it in this particular thread as no one has recommended he use the 7° 11/32 retainers with the 3/8 valves.
normally 7° retainers are stem diameter specific and 10° aren't
as for what retainer to use you need to know the spring ID as well because that's where the retainer will register, that will usually be diameter number two on the retainer specs. i'm assuming these are single springs?
