Denso 120 amp 2 groove pulley #1262068
07/05/12 11:23 AM
07/05/12 11:23 AM
Itasca, Texas
Mad_Scientist Offline OP
Itasca, Texas
I'm looking for the Denso 120 amp alternator with a 2 groove pulley. I called Mancini Racing and the tech stated that all of their Denso's come with a single groove pulley. He stated that my stock pulley would not bolt on.
I have seen the Denso alternator with a 2 groove pulley in the past. Where can I get this? I will also need the correct bracket to go with the alternator.
I appreciate any help you can give me.
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: Denso 120 amp 2 groove pulley [Re: Mad_Scientist] #1262069
07/05/12 03:12 PM
07/05/12 03:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Denso 120 amp 2 groove pulley [Re: Mad_Scientist] #1262070
07/05/12 03:19 PM
07/05/12 03:19 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
They're used on pre-Magnum EFI 318 and 360 engines.
Look for 88 to 93 truck and van applications.
- Stu Harmon
Re: Denso 120 amp 2 groove pulley [Re: feets] #1262071
07/05/12 04:15 PM
07/05/12 04:15 PM
Itasca, Texas
Itasca, Texas
Thanks for the info guys! I found one. It says the case size is 5-3/8. Now I just need to order the bracket, but I'm not sure if I should order the 60 amp bracket or the 120 amp bracket to fit this size case.
ACDELCO Part # 3351176 {#88877386} NEW UNIT
GENERATOR 137MM (5-3/8IN) DIA CASE; ND-IF 120AMP
68 F-100 SWB
Re: Denso 120 amp 2 groove pulley [Re: Mad_Scientist] #1262072
07/05/12 05:02 PM
07/05/12 05:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Mine hit the cylinder head when I installed it in the factory location. I had to do some creative mounting of bits to get things aligned.
- Stu Harmon
Re: Denso 120 amp 2 groove pulley [Re: feets] #1262073
07/05/12 05:11 PM
07/05/12 05:11 PM
Itasca, Texas
Itasca, Texas
Was that with AndyF's bracket? I read that you might have to grind down the stud on the alternator or do something to the plastic cover on the back, is that what was hitting?
68 F-100 SWB
Re: Denso 120 amp 2 groove pulley [Re: Mad_Scientist] #1262074
07/05/12 05:15 PM
07/05/12 05:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I haven't used Andy's bracket. I fabbed something to align it with the crank pulley on the hot rod. The crank pulley was spaced a bit by the crank trigger.
When I tried stuffing one on the Imperial it hit the cylinder head again. Not wanting to jack with everything on the Imperial, I grabbed a standard alternator and installed it.
- Stu Harmon
