Duel 4 Barrel Small Block Setup #1261616
07/04/12 02:17 AM
07/04/12 02:17 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Anyone running an inline duel 4 setup on your small block? If I need some ideas on setting up my throttle cable. The car is a 64 Dart, 273/4 speed.
Re: Duel 4 Barrel Small Block Setup [Re: dart4forte] #1261617
07/04/12 10:16 AM
07/04/12 10:16 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
slighty modified hemi linkage perhaps? Or summit sells cables/linkages for dual carb setups.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Duel 4 Barrel Small Block Setup [Re: DARTH V8Я] #1261618
07/04/12 12:16 PM
07/04/12 12:16 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
speedway motors also sells universal linkages for lots of different carb setups. if its the throttle cable bracket you need you might have to modify a stock one.
Re: Duel 4 Barrel Small Block Setup [Re: DARTH V8Я] #1261619
07/04/12 12:22 PM
07/04/12 12:22 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
slighty modified hemi linkage perhaps?...
That is what a friend in Oz did for his 273..
Re: Duel 4 Barrel Small Block Setup [Re: OzHemi] #1261620
07/04/12 12:38 PM
07/04/12 12:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The linkage on that 273 is the Hemi dual 4 design. If you want to run the Hemi linkage it should work as mentioned, with some light mods.
The more expensive/involved route......If you want it to be almost exactly like a Street Hemi you can add the Hemi style linkage arms to your carbs and the progresive linkage rod will work without any mods. The side arms were welded on at the factory (reccomended) but can also be screwed on to the ends of the throttle shafts (use red lock tight if you do!).
Re: Duel 4 Barrel Small Block Setup [Re: ScottSmith_Harms] #1261621
07/04/12 12:51 PM
07/04/12 12:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Edelbrock has a kit that is reasonably priced but could be duplicated for less, probably.
http://www.summitracing.com/parts/EDL-7094/?rtype=1
Installation instructions:
http://static.summitracing.com/global/images/instructions/edl-7094-dual_quad_linkage.pdf
Re: Duel 4 Barrel Small Block Setup [Re: OzHemi] #1261622
07/04/12 01:04 PM
07/04/12 01:04 PM
Mesa, Arizona
Mesa, Arizona
By any chance would you have a close-up shot of the throttle bracket and cable? As far as the linkage I'm leaning toward the hemi style
Re: Duel 4 Barrel Small Block Setup [Re: dart4forte] #1261623
07/05/12 01:46 PM
07/05/12 01:46 PM
Mesa, Arizona
Mesa, Arizona
Re: Duel 4 Barrel Small Block Setup [Re: dart4forte] #1261624
07/05/12 01:50 PM
07/05/12 01:50 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I just used two rod ends to tie the carbs together ( vac sec holley's)
and a regular lokar kit
Re: Duel 4 Barrel Small Block Setup [Re: dart4forte] #1261625
07/05/12 02:01 PM
07/05/12 02:01 PM
If your intake is a dual plane like the street hemi are use the progressive, if it is not use it one to one, not progressive I've had both types on motors and the single plane dual quad intakes hook up progressive suck bad One to one is way better on them You don't starve the front cylinders near as bad with one to one
Re: Duel 4 Barrel Small Block Setup [Re: Cab_Burge] #1261626
07/05/12 04:16 PM
07/05/12 04:16 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
With a low rise, you may be able to get the connection to the pedal off the rear carb and make a bracket using the stock cable.
When I did my tunnel ram, I needed a longer cable so I grabbed a /6 cable and built a bracket. I added an extension to the front carb and an adjustible linkage between the 2 carbs. Seemed to fit the space better, work better and stay in adjustment better that way (pull the front carb arm).
Re: Duel 4 Barrel Small Block Setup [Re: RodStRace] #1261627
07/05/12 06:12 PM
07/05/12 06:12 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
John, I can shoot a pic of my 6 pac linkage if that would help.
I am truckless..
Re: Duel 4 Barrel Small Block Setup [Re: 340SHORTY] #1261628
07/07/12 10:23 PM
07/07/12 10:23 PM
Mesa, Arizona
Mesa, Arizona
Yes, that would help/ Any pics will help. Also, I've decided to go with thge Lokar setup. Similar to the hemi setup.
