voltage regulator for 69 Coronet R/T #1261252
07/03/12 09:50 AM
07/03/12 09:50 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
The voltage regulator on my 69 R/T is unoriginal and the cover is unmarked smooth black plastic. Looking for a more OE look, but am unsure of how my original looked (red or yellow stamped).
Anyone have experience with these repo's? Do they work well? my SPD was Dec 68 so figured a date code of the 38th week of 68 was about right. for the price want to make sure I don't buy something very wrong or that function poorly.
Is the red stamp correct for my SPD of Dec 68?
http://www.megapartsusa.com/proddetail.asp?prod=112-VR388
TIA
Re: voltage regulator for 69 Coronet R/T [Re: BTTG] #1261253
07/03/12 09:59 AM
07/03/12 09:59 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
TIA
Kevin,
I seel the same regulator( just no stamp) and have never had a problem with function.
Not 100% sure but I think most of the 69's were yellow print.
Re: voltage regulator for 69 Coronet R/T [Re: gtx6970] #1261254
07/03/12 10:17 AM
07/03/12 10:17 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Thanks Bill.
My next question as I continue to read. What is the difference between an electronic regulator and a mechanical one? Can either be used independent of distributor? Right now I have a mopar electronic distributor in, but am going to install an original points distributor in the car real soon with a petronix inside it. Would this dictate/influence the regulator to be used?
Thought I read somewhere that early 69 builds had red stamp later were yellow....can't find where I read that though. Anyone have details when transition occurred?
Re: voltage regulator for 69 Coronet R/T [Re: BTTG] #1261255
07/03/12 10:27 AM
07/03/12 10:27 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Electronic ignition would benefit from the electronic controlled charging system with it's more constant/smoother voltages, but imo would not be a 100% required upgrade.
I've seen the red printed regulators but have it in my head they were more common in the 67 or maybe 68 or so model years.
Then again I remember something on the A12 board to the fact maybe early 69's had it as well, just not sure when the changeover was made.
A buddy of mine has several NOS ones and they are all red print, but they are non dated over the counter replacements
Re: voltage regulator for 69 Coronet R/T [Re: gtx6970] #1261256
07/03/12 07:08 PM
07/03/12 07:08 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
ones i have seen..68 and early 69 factory issue were yellow...later ones were red for some reason...i have a few of both NOS 67-9 date codes dan
Re: voltage regulator for 69 Coronet R/T [Re: ph23vo] #1261257
07/03/12 07:52 PM
07/03/12 07:52 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I always thought that 67-8 and heard very early 69 had RED.
Yellow was 69 (don't know how early though).
Re: voltage regulator for 69 Coronet R/T [Re: RJS] #1261258
07/04/12 12:30 AM
07/04/12 12:30 AM
alaska
69 mayflower Offline
alaska
My November 1968 built B Body has the red lettered regulator.Still the original one.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: voltage regulator for 69 Coronet R/T [Re: 69 mayflower] #1261259
07/04/12 12:38 AM
07/04/12 12:38 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i,m beginning to suspect it was a vendor deal..both could be correct if you don't have your original.. dan
