Page 1 of 3 1 2 3
Which Thermoquad? #1260482
07/01/12 09:56 PM
07/01/12 09:56 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I've gotten curious about Thermoquads and want to give one a try. I'm trying to find one that will run well on my engine (318 67 closed-chamber w Summit 6900) without any parts changing. I'd like to see if I get better throttle response and easier cruise tuning/economy than fidgeting with my AVS.
I've tried researching for my application, I'm a bit lost even with Vaanth's guide. With all of the different ones available on Fleabay and the like I'm really not sure what would be both a cheap & appropriate option for me. I know different years introduced different electronic emissions things that I probably don't want, but some earlier year carbs miss out on improvements done sometime in the 70s. Apparently some but not all later-70s carbs have a limiter or cap on the metering tree adjuster which kind of defeats one of my goals, etc.
What should I be setting my sights on?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Which Thermoquad? [Re: Secret Chimp] #1260483
07/01/12 09:59 PM
07/01/12 09:59 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
ANY of the 6000's series carbs. The metering rods w/ the 1966# on them are suppose to be the best starting point. Be careful with a first time removing the idle mixture screws on a carb that hasnt been used in a while, they are usually stuck and will break off.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Which Thermoquad? [Re: kilroy] #1260484
07/01/12 10:06 PM
07/01/12 10:06 PM
Eugene, Oregon
Eugene, Oregon
Everybody seems to be selling 9000 series. This is the typical "deal" I'm finding:
http://www.ebay.com/itm/1973-6324S-1083-...r#ht_2116wt_956
Is that what I ought to expect when looking for 6000s?
Re: Which Thermoquad? [Re: Secret Chimp] #1260485
07/01/12 10:49 PM
07/01/12 10:49 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Yep, looks about right.
Personally I wouldnt pay that much (because Im a cheapass)but I do love me some TQs. 9000s can be made to work, but are generally loaded down with extra emissions equipment and you have to know what to tune,cover,remove to make those carb work. I find about 1 6000's series for every 5 9000's series. You can still find them at swap meets (all series) for $5-$40 with most around $25. This will also be where you get your spare parts. Lots of good threads on here would be gald to post them for you, all sorts of things covered.
Re: Which Thermoquad? [Re: kilroy] #1260486
07/02/12 12:48 AM
07/02/12 12:48 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
One word: Demonsizzler
Re: Which Thermoquad? [Re: OrangeProwler] #1260487
07/02/12 12:52 AM
07/02/12 12:52 AM
Eugene, Oregon
Eugene, Oregon
Isn't he out of the business or something?
I thought I read an inquiry a few months ago about where he was and a friend/forum member said he'd sold all of his stuff.
Re: Which Thermoquad? [Re: Secret Chimp] #1260488
07/02/12 09:29 AM
07/02/12 09:29 AM
Lexington NC
twinscrew698 Offline
Lexington NC
His web site is down!
Members had trouble getting a hold of him!
Might wanna try http://harmsauto.com/
Scottsmith Harms is a member here!
Quality work of what i have seen!
Re: Which Thermoquad? [Re: twinscrew698] #1260489
07/02/12 11:13 AM
07/02/12 11:13 AM
Eugene, Oregon
Eugene, Oregon
I'd love to get a TQ done by Scott, but if I had that kind of money to throw at my car I'd have a lot less questions to ask
Re: Which Thermoquad? [Re: Secret Chimp] #1260490
07/02/12 12:18 PM
07/02/12 12:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty much any early pre smog TQ 6000/9000 series will work well on your small block, I have some good cores on hand, If it helps your budget amy you buy the restoration I'll give you a free core (I have several early 70's 340/360 #s on hand). Good luck either way
Re: Which Thermoquad? [Re: Secret Chimp] #1260491
07/02/12 02:31 PM
07/02/12 02:31 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Hey Secret Chimp, I see you are in Bothell. There is a local guy in Arlington that is AWESOME with TQ's. He has done several for me and just built one for my MH. That one cost me $275. He loves TQ's and has a stockpile of them even the 1000 cfm ones. PM me and can get you his #.
Re: Which Thermoquad? [Re: 77ProStreet] #1260492
07/02/12 03:47 PM
07/02/12 03:47 PM
Eugene, Oregon
Eugene, Oregon
Would something like this work, or is it on the wrong edge of emissions?
http://www.ebay.com/itm/CARTER-THERMOQUA...tr#ht_500wt_971
Re: Which Thermoquad? [Re: 77ProStreet] #1260493
07/02/12 03:48 PM
07/02/12 03:48 PM
Eugene, Oregon
Eugene, Oregon
Thanks for the offer, not calling your prices steep, I'm just poor
Nice, PM sent
Re: Which Thermoquad? [Re: Secret Chimp] #1260494
07/02/12 05:32 PM
07/02/12 05:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem, good luck
Re: Which Thermoquad? [Re: ScottSmith_Harms] #1260495
07/03/12 01:18 AM
07/03/12 01:18 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Don't waste your time or money on a 9000 series. Get a 6000 series. End of discussion. Period.
Also, since you're putting on one a 318, get one for a small block. You will be happier with it than trying to make a big block carb work. This will limit you to 73-74 340/360 carbs but you will have much better luck with one of those. Get a rebuild kit, they are not tough to rebuild. They can be tricky to tune however.
Re: Which Thermoquad? [Re: DaytonaTurbo] #1260496
07/03/12 08:01 AM
07/03/12 08:01 AM
Lexington NC
Lexington NC
Believe me when i tell ya this!
But after paying shipping back and forth and getting Carbs that simply do not work,I wished i would just bought one and been done with it knowing that it works is worth the money to me in my own opinion!
Ask me how i know!
Luckily when Demonsizzler was doing carbs he stood by his work was easy to get a hold of and all i had to do was pay shipping one way because i did not have the extra money to buy a Fuel bowl, i just had him fix it and sent him another bowl to rebuild it finally got one that was not cracked!
I am in the same boat for money but knowing i can get a Quality Thermoquad Rebuilt and tested is worth the extra money for me without all of that hassle of back and forth shipping and doing w/o a Carb for that long!
Re: Which Thermoquad? [Re: twinscrew698] #1260497
07/03/12 09:35 AM
07/03/12 09:35 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I would say the above post is conditional.
If you like to work on your stuff, the problems you here about with TQs are not big issues at all and you will find them easier to work on than people claim.
If you like the hobby but dont really want to understand the system or think tearing into a carburetor would be over your head, then yes, you may be money ahead to have a guy like Scott rebuild and set it up for you.
The intial evaluation of the carb as it comes apart will tell you a lot. Is it missing any parts you dont have, is it seized, etc.
Re: Which Thermoquad? [Re: kilroy] #1260498
07/04/12 06:47 AM
07/04/12 06:47 AM
Lexington NC
Lexington NC
I agree!I have taken my Thermoquad apart many of times and have no problem of doing it again,thats how we learn!
It was a lot less complicated than i thought once i got in to it!
Re: Which Thermoquad? [Re: twinscrew698] #1260499
07/04/12 11:05 AM
07/04/12 11:05 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
In the fall of 1973, I was 16 and my parents bought me a new 360 Duster. Im not sure which series carb came on that model, but even today I have kept it because a very very good carburator man who was absolutely top notch on Quadrajets etc rebuilt it for me to run with a purple cam and 4:10 rear end. To this day I have kept that carb because it never bogged on me, and the kick in was phenomenal. I have used a few Holleys since then but never have I had a carb since then that was so low maintenance and responsive.
Would someone chime in on which series this is? In any case, all these years later after years of racing up until my late 20s, I never had such a responsive carb. 800 or 850cfm? I dont remember anymore. What it be appropriate enough for a warm .060 440 motor with a 3:55 rear end with a cam just under 500 lift.
Re: Which Thermoquad? [Re: gomangoRTSE] #1260500
07/04/12 11:13 AM
07/04/12 11:13 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The 6000 series carbs were used from 1972 through 1974, the 9000 series followed them.
Re: Which Thermoquad? [Re: ScottSmith_Harms] #1260501
07/04/12 02:12 PM
07/04/12 02:12 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
There is an after market 9000 series. 9801-9800's.
Keep in mind our resident "mileage master" used a 850 sized TQ on his 318. I forget what model it was. (Maybe a 400HP carb?)
The one you showed on Ebay is a carb with an altitude compensator.
I own 30 TQ cores. All of them will require the primary throttle shaft to be bushed. Unless you have to tools to do it? You might have to hire someone to do that.
If anyone needs to get one of Doc's air door tools I can try contacting him. I have his number and email.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Page 1 of 3 1 2 3
