Trouble with Edelbrock
#1260297
07/01/12 03:39 PM
07/01/12 03:39 PM
Posts: 487 Sonoran desert, Arizona, USA
moparjo68
Hi. I have a rebuilt 383 w/ a mild cam, stock 4 bbl intake and a 650 edelbrock carb w/electric choke. The carb has to be primed each and every time after sitting overnite or I just crank for 30 plus seconds. Once started, the motor will idle beautiful. No problems with warm up. DOES NOT TRY TO DIE when put in drive. No flat spots on exceleration. But when operated for 30 minutes or more, the motor starts to spit, splutter, and try to choke out only at low idle. Turn off motor, smell raw fuel. When I restart, motor does not want to start. (Electric choke is wide open. No problems w/choke) Have to press gas pedal half way to floor to finally get to start and I have to keep foot on gas pedal to keep motor running. Motor acts like its running on 4 cylinders. Read on Moparts about gas percolating in carb so I bought a half inch phelonic spacer. No change. So I bought a one inch spacer. No change. Tore carb apart. Checked float levels. They are perfect to factory specs. About ready to throw this EDELBROCK carb in garbage.
I once rebuilt a GM 400 and put a Carter AFB straight out of box. Had NOT ONE OUNCE of problems with the Carter. Tried to purchase a Carter AFB once again before purchasing Edelbrock I currently have but sadly found out I couldn't purchase Carter AFB's new anymore. Would love to hear from someone who has had similar problems and what carb did they change to to finally eliminate problems as I have mentioned. If changing back to Carter would eliminate this problem, I would search for a good used AFB or one to rebuild. Please help! Thanks, Joe
Re: Trouble with Edelbrock
[Re: moparjo68]
#1260303
07/01/12 04:24 PM
07/01/12 04:24 PM
Challenger 1
Cincinnati, Ohio
Get rid of the filter before the pump it doesn't go there, it goes after the pump. The new sock in the tank is all that's needed and it's the way our cars came new. The 10 micron filter your using makes it really hard to suck gasoline through and can't be done when it get's hot. And to the guys who say "I've been doing it for years", well it's wrong and todays gas can't tolorate it near as well as the old gas or racing gas.
[Re: Challenger 1]
#1260304
07/01/12 04:30 PM
07/01/12 04:30 PM
moparjo68
I had fuel filter in factory location at one time. Problem existed then as now. Someone wrote on board that your problem was fuel filter needs to be behind fuel pump. So I moved it to present location. No change.
[Re: moparjo68]
#1260305
07/01/12 04:36 PM
07/01/12 04:36 PM
Challenger 1
Cincinnati, Ohio
Well I can promise you the filter will be much more useful to you after the pump.
I think you should try it without and get back to us. I'm also postive it can't go there, no way will it work. Also I think you should jet it up one step too and make sure it's not building heat from being lean. How's the motor run? If it is lean, it will get the motor hot and affect fuel pump performance. Or it could be timing...
[Re: moparjo68]
#1260307
07/01/12 04:42 PM
07/01/12 04:42 PM
Posts: 3,916 usa
lewtot184
usa
never put a filter (unless its a high micron screen) on the suction side of a pump.
[Re: Challenger 1]
#1260308
07/01/12 04:44 PM
07/01/12 04:44 PM
RapidRobert
Above idle see if the boosters are dripping. Mine are with a stock 318 mech pump. May need a regulator. come payday I'm getting a holley low psi one for my 1406 Eddy.
[Re: RUNCHARGER]
#1260313
07/02/12 01:16 AM
07/02/12 01:16 AM
Posts: 3,899 Oregon
hooziewhatsit
Did you check to see if the boosters are spitting at idle like RapidRobert suggested? Also, I would check the fuel pressure to make sure it's not too high (nothing above 5.5psi EVER). When it's hot, turn it off, remove the air cleaner and look down the throats. If you see fuel pushing past anything, you have an issue somewhere. Allegedly Holleys are slightly better in the heat soak department since the bowls are insulated with gaskets from the main body, but then you would have a holley
[Re: RapidRobert]
#1260314
07/02/12 01:44 AM
07/02/12 01:44 AM
moparjo68
I don't know what you mean by the boosters. Also, what did you mean by getting a holley low psi for your 1406 Eddy? Do you mean in exchange for?
[Re: moparjo68]
#1260315
07/02/12 02:25 AM
07/02/12 02:25 AM
Posts: 840 southern Idaho
moparcyco
southern Idaho
Is that a 600 edelbrock or a 750?Dont think they have a 650.If it is a 750 throw that POS in the trash.600 will work fine same with an 800.This is not an edelbrock bashing,I have used 600 and 800's with great results.I had a 750 on a hot 360 had every problem you've described and then some.Started doing some reasearch and come to find out these carbs are CRAP.I would borrow another carb if you can and see if your problem goes away.If not fuel system somewhere
