Re: MT ET Streets. When are they done?
[Re: pinkduster]
#1260105
07/01/12 03:50 PM
07/01/12 03:50 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Geee,,,,,,,,,,,,,thanks
[Re: OUTLAWD]
#1260107
07/01/12 10:55 PM
07/01/12 10:55 PM
hemi-itis
How about backing into your own rubber,anyone try that yet??
[Re: hemi-itis]
#1260108
07/01/12 11:03 PM
07/01/12 11:03 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Cab,are you sayin' that I might acually finally get traction in the street???? .....wait
Probally a lot more than you have now with those(Pro or Sportsman Pros) tires on their best day I can spin them on the street, 13.5x30x15 with 15+ lbs in them, they dead hook at 9.0 to 11.0 lbs at the track, 1.41 60 ft. times. If I run 10 lbs on the street they will spin a little and then hook. The ET Street Radials of the same size will not hook on the street with my car The radials are faster at the track(1.39 60 ft last weekend ), when it is good, than the bias plys are If the track is bad the bias plys are easier to drive and race on
[Re: hemi-itis]
#1260109
07/01/12 11:11 PM
07/01/12 11:11 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Yeah, I tried it. I did a 10 second tire melting burnout and laid down 50 feet of melted rubber down on the highway on a hot day then backed onto my tracks with my 26x11.5 et streets @ 15 lbs. Net result was worthless, My typical 4500 rpm launch that I can occasionally hook here and there turned into 200' of tire stripes- so for me- there was no gain in traction.
[Re: 72demon416]
#1260111
07/02/12 10:24 PM
07/02/12 10:24 PM
hemi-itis
Thanks,they did not come in yet but that's what I will try.I still need to buy new belts and recert the car.
