best street/ strip torque converter.
#1260039
06/30/12 10:17 PM
06/30/12 10:17 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Im in the market for a good street/ strip converter for my 71 340 roadrunner with a FAST legal 430 cu in. I have a stout 904 built for it also. Ill be running a 3.55 with G60-15's. I know there are some very reputable brands, but would like peoples personal experiences to help me decide. cost is also a factor also.. Ill list a poll with 2 brands I know will be mentioned. thanks! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: best street/ strip torque converter.
[Re: mopars_1]
#1260040
06/30/12 10:25 PM
06/30/12 10:25 PM
mopars_1
Ridgeland Wi
crap, I posted this in the restoration section. mods, please move..
[Re: mopars_1]
#1260042
07/02/12 02:21 PM
07/02/12 02:21 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have used an off-the-shelf Dynamic that worked good in my old setup, and I had Ultimate build me a custom converter for my new setup, and it works great, but it was more expensive. I'm not sure how price compares to other custom built converters? Lenny, at Ultimate was great to work with, and built me a tight 9" converter for my street/strip Charger. The converter works great on the street with almost no slippage until you really get into the throttle, then it flashes to around 5,000 RPM. It is hard to say how it is doing at the strip? I think because it is tight, it does not seem to hit real hard on the launch, but that's good for my "street" car which is using stock leaf springs and E/T street tires.
[Re: mopars_1]
#1260044
07/02/12 10:32 PM
07/02/12 10:32 PM
Posts: 12,301 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Call PTC, they are Mopar guys and get it right the first time without breaking the bank.
Master, again and still
[Re: AdamR]
#1260048
07/03/12 10:51 PM
07/03/12 10:51 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Converter is one place not to go cheap on. It can make or brake your combo. I would talk to the other FAST guys and find out who they are using.
So if you compare a stock or performance converter to a "purpose built" converter, where would you expect to see gains? The car would not 60 foot any better because it has no slicks on it [or would it?]
Would/should E.T. and/or MPH would increase?
Would a "true stock" car benefit from a "purpose built" converter? [no other changes}
[Yes I race my car, that is why I'm asking]
[Re: AdamR]
#1260050
07/04/12 12:55 PM
07/04/12 12:55 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
yes it would benefit because a converter is not just about launching hard. A good converter will pull harder through the whole 1/4. Its about efficiency. Cheap converters will also slip at high RPMS.
Maybe less important on a stock or mild car but theres still plenty of room for improvement there too.
my road runner never did this until I put the Dynamic converter in.....hooked up and put these tire marks as far as the road would let me. Before with the TCI it got to the darker marks where it went into 2nd and that was it, with the Dynamic it pulled and pulled I'm sure the Ultimate and a couple of others (even a good TCI) it would do the same, but I agree that a good torque converter is key to getting the most out of your car setup. BUY A GOOD ONE and don't buy price!
![](http://a12mopar.com/yabb/Attachments/DSC08736rs.jpg)
[Re: mopars_1]
#1260051
07/10/12 11:35 PM
07/10/12 11:35 PM
mopars_1
Ridgeland Wi
alright, I ended up calling dynamic and got one ordered. seems like they know what they are talking about and it was a little cheaper than ultimate converters ($699 compared to $890) thanks for everyone's insight! -kevin
[Re: mopars_1]
#1260052
07/12/12 12:29 AM
07/12/12 12:29 AM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
I, for one would be interested in update info after you are up and running and tested. Steve
[Re: pacifica]
#1260053
07/12/12 12:55 AM
07/12/12 12:55 AM
mopars_1
Ridgeland Wi
it may be a while. if you keep up on my young gun 71 340 roadrunner, ill keep posts on there
[Re: mopars_1]
#1260054
07/12/12 05:27 PM
07/12/12 05:27 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Do you have a link so i can follow? Thanks
[Re: pacifica]
#1260055
07/12/12 08:47 PM
07/12/12 08:47 PM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
I never hear Turbo Action's name tossed around here anymore. I picked up a 10" 17809ST from them last year and couldn't happier. My car still launches strong, but doesn't feel like a wet noodle at cruise as it did with the TCI.
[Re: MarkZ]
#1260056
07/12/12 09:19 PM
07/12/12 09:19 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I just installed a custom built Dynamic 9-1/2" unit this spring. I was replacing an ACC "Boss Hogg" 11" unit that was rated @ 3200-3600. The new Dynamic unit is noticably looser down low, but seems to be more efficient at freeway speeds. Last weekend was my first time at the track with it, and I picked up 1.3 tenths in 60', and a solid 3 tenths in ET, before ending my night with a broken 8-3/4". So far, I'd say the converter Shaun spec'd for me is money well spent. I might have chosen to be not quite so loose down low for around town driving, but I did tell him it was "street driven", as opposed to a "street-car". Either way, I feel really good about the money I spent with them.
[Re: mopars_1]
#1260058
07/13/12 02:10 PM
07/13/12 02:10 PM
Posts: 37 Canada's West Coast
Graham
Canada's West Coast
What ever you do, don't let price be your guide. I know that $$$ are hard to find, but a poorly spec'd converter or a price only converter can be your worst nightmare. Properly applied, they're great, poorly applied a bad, bad performance investment. ![](/ubbthreads/images/graemlins/tsk.gif) Your converter supplier should ask you a lot of questions before letting you know what is the RIGHT ONE FOR YOUR CAR!!. I worked in the industry, and saw lots of fellows get the wrong converter for their particular application. I've attached a spec sheet we asked customers to fill out. BE TRUTHFUL about the information you're supplying and your converter supplier will get your the one you need.
