trying to turn over long dormit 383 #1259875
06/30/12 04:24 PM
06/30/12 04:24 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
The convert has set for bout 8 years
i got it into the shop (its long needed new home)
hooker jumper box to the cables put top down
tried bumping key to see if motor would spin but just get a click on passenger side guiessing somewhere around #8 cyl and dipstick tube area
Any thoughts????
im not starting it till gets primed right now just trying to get it to bump over
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: trying to turn over long dormit 383 [Re: toplescuda] #1259876
06/30/12 04:34 PM
06/30/12 04:34 PM
places
79powerwagon Offline
places
Put a wrench on it instead, and you'll know right away.
Re: trying to turn over long dormit 383 [Re: 79powerwagon] #1259877
06/30/12 04:44 PM
06/30/12 04:44 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Thats a thought but id have to take rad. Out and fan/shroud off not ready to start taking car apart right yet
i fig the motor will be locked
right now just trying to fig out what would be clicking on passenger side???
1971 charger
Re: trying to turn over long dormit 383 [Re: toplescuda] #1259878
06/30/12 04:46 PM
06/30/12 04:46 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Starter relay?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: trying to turn over long dormit 383 [Re: toplescuda] #1259879
06/30/12 05:11 PM
06/30/12 05:11 PM
I'd clean the batt cables/terminals/posts & retry
Re: trying to turn over long dormit 383 [Re: HemiRick] #1259880
06/30/12 05:32 PM
06/30/12 05:32 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Starter relay?
relay is on driver side same side as starter
1971 charger
Re: trying to turn over long dormit 383 [Re: toplescuda] #1259881
06/30/12 05:44 PM
06/30/12 05:44 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
If you didn't oil down the cylinders they are rusted.
Re: trying to turn over long dormit 383 [Re: moparpollack] #1259882
06/30/12 05:49 PM
06/30/12 05:49 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
You can get a socket, short extension, and a breaker bar in there; I do it all the time on my Roadrunner. I'd pull the plugs and squirt some Marvel Mystery Oil or regular oil down in there, let it sit for a bit, then get manly with the breaker bar. Unless you plan to rebuild the thing, I'd do the oil & filter and spin up some oil pressure before lighting it off.
(PS: "dormant")
Re: trying to turn over long dormit 383 [Re: toplescuda] #1259883
06/30/12 06:24 PM
06/30/12 06:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would 'bump' the relay and track down the noise from under the hood. could just be a ground strap if there is one from the back pass head to the firewall.
Re: trying to turn over long dormit 383 [Re: topside] #1259884
06/30/12 07:12 PM
06/30/12 07:12 PM
You can get a socket, short extension, and a breaker bar in there; I'd pull the plugs and squirt some Marvel Mystery Oil or regular oil down in there, let it sit for a bit, then get manly with the breaker bar. Unless you plan to rebuild the thing, I'd do the oil & filter and spin up some oil pressure before lighting it off.
Re: trying to turn over long dormit 383 [Re: RapidRobert] #1259885
07/01/12 03:48 AM
07/01/12 03:48 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Any engine that has sat dormant for that long will benefit from soaking the cylinders.
Re: trying to turn over long dormit 383 [Re: Kern Dog] #1259886
07/01/12 05:23 AM
07/01/12 05:23 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I had planed on pulling the plugs its the clicking when o hit the key im trying to fig. Out
1971 charger
