Re: 68 RR Documented Complete Rebuild? [Re: 68jim] #1259754
07/03/12 10:40 AM
07/03/12 10:40 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
petty43,
I finished my 68 road runner a few years ago so some stuff I can remember. I took plenty of pictures - most have been posted on Moparts at one time or another. Post your questions or send a PM. I'll help as much as I can.
Good Luck!
Jim,
Thank you. You did a great job on your car. Nice and clean.
I like the hood black out too and have tossed around adding it on mine to break up the green a little.
Tim
1968 Satellite RR Copy Cat My Fleet
Re: 68 RR Documented Complete Rebuild? [Re: petty43] #1259755
07/03/12 11:01 AM
07/03/12 11:01 AM
Retired now in Tennessee
Chi_Town_Runner Offline
I had some conversations with Jim about his hood black-out. With his advise I did mine and have never looked back.
My advise, do it like Jim's. You'll be happy you did.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 68 RR Documented Complete Rebuild? [Re: A12] #1259756
07/03/12 11:04 AM
07/03/12 11:04 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Now how about a simple 10-points of order of assembly from everyone that has assembled a car after paint. You know like:
1. Install engine and transmission.
2. Finish engine compartment.
3. Install wiring then install dash.
4. Install vinyl roof....oops make this #1. or number 12.
5. Install carpet.
6. Install instruments.
7. Oops remove carpet so you can find seat and console mounts and oops wait because you forgot to install the head liner and locate the shoulder belt mounts..
You know what I mean There were lots of things that I had to undo more than redo because I got ahead of myself from inexperience so post your own list of just the basic steps. I'm sure if I did my list there would be lots of tips as to what I should have done before I did them......like sealing in the windshield BEFORE I put the dash in....which as most of you know "you can't put the dash in AFTER putting in the windshield
You missed it just above your post...
http://www.restorick.com/tech/topic.asp?TOPIC_ID=58
Re: 68 RR Documented Complete Rebuild? [Re: RestoRick] #1259757
07/03/12 11:15 AM
07/03/12 11:15 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
5. Install carpet.
I SURE DID!! THAT'S A GREAT LIST Rick
MikeR
Re: 68 RR Documented Complete Rebuild? [Re: A12] #1259758
07/03/12 05:45 PM
07/03/12 05:45 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Re: 68 RR Documented Complete Rebuild? [Re: RestoRick] #1259759
07/04/12 04:17 PM
07/04/12 04:17 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I created a photobook documenting the restoration of my 70RR. It is still online. Go here and enter 118305 in the search box. Click on the thumbnail and the photobook should come up with a "Flip Preview" option. Just click on each page and it will flip through the book.
And, I used Rick's list as a general guide.
Re: 68 RR Documented Complete Rebuild? [Re: petty43] #1259760
07/07/12 03:10 AM
07/07/12 03:10 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Is that JJ1 poly gold?
FF1 mist green poly or something like that.
Isn't FF1.. Light Forrest Green Metallic?
Re: 68 RR Documented Complete Rebuild? [Re: 52savoy] #1259761
07/07/12 10:58 AM
07/07/12 10:58 AM
I show
FF1 = Mist Green Metalic and GG1 = Forest Green Metalic.
Frank
Re: 68 RR Documented Complete Rebuild? [Re: Chi_Town_Runner] #1259762
07/07/12 01:01 PM
07/07/12 01:01 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I show
Frank
and sometimes Mist Green Poly but I always knew it as Mist Green Metalic
Re: 68 RR Documented Complete Rebuild? [Re: Chi_Town_Runner] #1259763
07/07/12 01:25 PM
07/07/12 01:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I show
Frank
The two colors side by side and there is no mistaking which is which
My '68 FF1 road runner next to a friend's '68 GG1 Forest Green Charger
Re: 68 RR Documented Complete Rebuild? [Re: A12] #1259764
07/07/12 01:32 PM
07/07/12 01:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've seen where JJ1 gets confused with a mid-green color depending on the light it was photographed in,(as stated above and forgot) might be what you were thinking of, just throwing that out there because I do that all of the time
Re: 68 RR Documented Complete Rebuild? [Re: A12] #1259765
07/07/12 01:36 PM
07/07/12 01:36 PM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
I have lots of pictures also. Drip rail moulding doesn't get in the way of anything. I did my head liner, you need to go out a buy about 12 little spring clamps for that job. Is your car factory air with that big round hole in the firewall?
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: 68 RR Documented Complete Rebuild? [Re: A12] #1259766
07/07/12 06:00 PM
07/07/12 06:00 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I show
Frank
Memory can be a strange thing.. and it's been about 25 years since I painted my roadrunner. But it seems there were 2 different dated charts for '68 and one listed FF1 as "Lt Forrest Green Met." and it was the lightest of the grns.. The chart I'm referring to showed 3 shades of green for 1968.
I've seen the 3 diff. distinct colors on Plymouths too.
Other sources call it that. Why?
http://www.wwnboa.org/68bgar.htm
Where is my back up when I need it...
Re: 68 RR Documented Complete Rebuild? [Re: 52savoy] #1259767
07/07/12 06:10 PM
07/07/12 06:10 PM
one listed FF1 as "Lt Forrest Green Met." .... showed 3 shades of green for 1968
You may have seen the paint chart for Chrysler/Imperial in '68. Same colors and numbers but different names.
In '68 FF1 on Chrysler/Imperial was Frost Green Metalic
and
GG1 was Forest Green Metalic
There was a 3rd green, TT1
Plymouth = Avacado Green Metalic (Poly)
Dodge = Medium Green Metalic (Poly)
Chrysler/Imperial = Meadow Green Metalic (Poly)
Just my
Anything is possible with Mopar.
Frank
Re: 68 RR Documented Complete Rebuild? [Re: Chi_Town_Runner] #1259768
07/07/12 06:21 PM
07/07/12 06:21 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
thanks Frank.
Re: 68 RR Documented Complete Rebuild? [Re: NAS Backyard] #1259769
07/09/12 12:46 AM
07/09/12 12:46 AM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Yes it's factory a ac car. It is really a satellite 318 car but don't tell anyone.
