Re: best stuff to spray machined crank?
[Re: 440forPOWER]
#1259677
06/30/12 05:26 PM
06/30/12 05:26 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I've been using Marine fogging oil with good results.
[Re: TrxR]
#1259681
06/30/12 08:38 PM
06/30/12 08:38 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Not a fan of WD-40. The carrier evaporates over time and leaves a hard to remove film on the surface. I have found that water displacing silicon spray works well.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: HPMike]
#1259682
06/30/12 10:40 PM
06/30/12 10:40 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Only a month or two????
Frankly the oil residue left behind from the crank shop will probably keep it well protected if its stored in a temperature stable environment. If it really worries you, you can just put a thin coat of assembly lube on the journals..
MB
But if you must use something, either Cosmoline or Starret Protective lube.
RIP Monte Smith
[Re: mopardamo]
#1259684
07/01/12 01:12 PM
07/01/12 01:12 PM
Posts: 1,443 Maryland
Dads426
Maryland
No matter what lubricant you use, bagging it keeps moisture out and keeps the crank clean. Kept cranks this way for years and no corrosion. If you can't or don't want to store it vertically, buy a hole saw the diameter of the main journal, a 1x6 and create a cradle with three supports and the crank will store on a shelf or under a workbench, etc.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 440forPOWER]
#1259687
07/01/12 09:58 PM
07/01/12 09:58 PM
Posts: 914 tn
robnbird
tn
My crank is back from machining. And I probably won't get to assembly for a month or two. What is the best stuff to coat the crank to prevent any rusting? Wd40? Motor oil? Thanks
not wd40 ! white lube in the aerosol can will do a good job as a lube and keep air and moisture away from the metal.
