best stuff to spray machined crank? #1259671
06/30/12 12:56 PM
06/30/12 12:56 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
My crank is back from machining. And I probably won't get to assembly for a month or two. What is the best stuff to coat the crank to prevent any rusting? Wd40? Motor oil? Thanks
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259672
06/30/12 01:01 PM
06/30/12 01:01 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
WD40
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259673
06/30/12 01:02 PM
06/30/12 01:02 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Re: best stuff to spray machined crank? [Re: RV2] #1259674
06/30/12 01:04 PM
06/30/12 01:04 PM
Moparnut426 Offline
Moparnut426  Offline
WD40
WD40 works for a while, but in high Nebraska humidity Cosmoline is the best thing.
Ive tried WD40 only to have a crank need polished again before assy. Seems like ya have to respray it several times in a month.
Cosmoline coats and stays.
OH, yes csmoline is spendy, but the machine shop who cut your crank should have some laying around and for a small fee might put some on for ya.
Re: best stuff to spray machined crank? [Re: Moparnut426] #1259675
06/30/12 03:56 PM
06/30/12 03:56 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Don't forget to store it vertically....
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259676
06/30/12 04:05 PM
06/30/12 04:05 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Only a month or two????
Frankly the oil residue left behind from the crank shop will probably keep it well protected if its stored in a temperature stable environment. If it really worries you, you can just put a thin coat of assembly lube on the journals..
MB
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259677
06/30/12 05:26 PM
06/30/12 05:26 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've been using Marine fogging oil with good results.
Nautilus Racing-
Re: best stuff to spray machined crank? [Re: Chris2581] #1259678
06/30/12 06:01 PM
06/30/12 06:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Keeping it bagged after spraying/coating it with the oil of your choice will help. I've stored bagged stuff like that indoors (heated shop) for years with no corrosion.
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259679
06/30/12 06:10 PM
06/30/12 06:10 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Chassis grease.
Sheldon
Re: best stuff to spray machined crank? [Re: RUNCHARGER] #1259680
06/30/12 07:23 PM
06/30/12 07:23 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
Fluid Film works great
Re: best stuff to spray machined crank? [Re: TrxR] #1259681
06/30/12 08:38 PM
06/30/12 08:38 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Not a fan of WD-40. The carrier evaporates over time and leaves a hard to remove film on the surface. I have found that water displacing silicon spray works well.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: best stuff to spray machined crank? [Re: HPMike] #1259682
06/30/12 10:40 PM
06/30/12 10:40 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
MB
But if you must use something, either Cosmoline or Starret Protective lube.
RIP Monte Smith
Re: best stuff to spray machined crank? [Re: CompWedgeEngines] #1259683
07/01/12 01:46 AM
07/01/12 01:46 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Ive used Boeshield T 9. Reportedly made by Boeing for parts after machining.
Damon
Re: best stuff to spray machined crank? [Re: mopardamo] #1259684
07/01/12 01:12 PM
07/01/12 01:12 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
No matter what lubricant you use, bagging it keeps moisture out and keeps the crank clean. Kept cranks this way for years and no corrosion. If you can't or don't want to store it vertically, buy a hole saw the diameter of the main journal, a 1x6 and create a cradle with three supports and the crank will store on a shelf or under a workbench, etc.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: best stuff to spray machined crank? [Re: Dads426] #1259685
07/01/12 07:11 PM
07/01/12 07:11 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Brake out the K/Y and bag it good
Re: best stuff to spray machined crank? [Re: emarine01] #1259686
07/01/12 09:50 PM
07/01/12 09:50 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Don't you have it backwards?
Re: best stuff to spray machined crank? [Re: 440forPOWER] #1259687
07/01/12 09:58 PM
07/01/12 09:58 PM
tn
robnbird Offline
robnbird  Offline
tn
not wd40 ! white lube in the aerosol can will do a good job as a lube and keep air and moisture away from the metal.
