318 roller cam ? #1259603
06/30/12 10:52 AM
06/30/12 10:52 AM
CALIFORNIA - central
junkyard Offline OP
junkyard  Offline OP
I have an 86 B200 Dodge van w/318 la engine.
Is there any way to tell if this is a roller cam engine without taking it apart?
Re: 318 roller cam ? [Re: junkyard] #1259604
06/30/12 11:10 AM
06/30/12 11:10 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if it is the original motor it will not be a roller cam, only cars got roller cams in that year. it will be a roller block though.
Re: 318 roller cam ? [Re: 65rbdodge] #1259605
06/30/12 11:47 AM
06/30/12 11:47 AM
scratchnfotraction Offline
my 85 truck was roller block,came with flat tappet,i swaped it to roller came with all stock roller gear.
the 88 4-v gran fury cop engine I have was the same thing,roller block with flat tappet. swaped it to roller cam also. used 1990 tbi roller gear.
only cars with 2-v/tbi got a roller cam starting in 85,truck went roller cam in 89 with tbi,all trucks/4-v engines got a flat tappet till 89.
remember... roller cam engines with carbs/mech fuel pumps got the long nose cam,tbi engines got the short nose cam with no mech fuel pump.
I used a lunati voodoo roller cam with a long nose to swap mine over with all stock valve gear and used a set of comp 901-16 springs.
my last set of stock roller lifters got over 300,000 miles before I shelved them.
Re: 318 roller cam ? [Re: scratchnfotraction] #1259606
06/30/12 08:49 PM
06/30/12 08:49 PM
junkyard Offline OP
junkyard  Offline OP
Thank you
