Indy's CNC ported 360-1 heads #125956
09/25/08 09:07 AM
09/25/08 09:07 AM
South Carolina
a408swinger Offline OP
mopar addict
mopar addict
South Carolina
How do they flow out of the box, and do they need work before running for optimal performance. Thinking of selling my 360-1's I have now and getting the big cnc ported ones. The motor is a 14 to 1 R3 59* motor with a solid roller 281/288 @ .050 with a .661/.664 lift with a big shot plate and a fogger. Feedback please
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125957
09/25/08 09:19 AM
09/25/08 09:19 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
What cubic"? We have had great luck with the 360-1 CNC-245 with flow over 330 cfm @700 with a lot of compression.Other than touching up the valve job and correcting all the spring height They are pretty good the way the come.
Re: Indy's CNC ported 360-1 heads [Re: B G Racing] #125958
09/25/08 09:26 AM
09/25/08 09:26 AM
South Carolina
mopar addict
mopar addict
South Carolina
Im sorry, the motor is 408". The car is 2940 with me in it and its been a 5.60 @ 127 on the sauce so far but havn't had it on the dyno to tune it yet. A good friend of mine is looking for some 360-1's so I thought about selling him mine and stepping up to the 245cc cnc heads. Mine have already been ported and just curious if I will see an improvement with the cnc heads over fully hand ported heads.
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125959
09/25/08 09:40 AM
09/25/08 09:40 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I've never checked out a 360-1 head of any version but, the
CNC 230cc 360-2 heads need a little hand work and valve
job. IIRC, flow was a little unstable at most of the usable
lift points.
Re: Indy's CNC ported 360-1 heads [Re: S/ST 3040] #125960
09/25/08 11:19 AM
09/25/08 11:19 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
it's fun making power out of a 59* block and the 18* head.Im not sure if this is right to say but at the beginning i did't like the indy idea, but heyy the head is there, not like the MP stuff, just call Ryan J. he's been working on my 255cc indy heads...
Re: Indy's CNC ported 360-1 heads [Re: SB449VALIANT] #125961
09/25/08 11:25 AM
09/25/08 11:25 AM
Mcallen, TX
Mcallen, TX
here are some flow #'s web page
Re: Indy's CNC ported 360-1 heads [Re: SB449VALIANT] #125962
09/25/08 12:34 PM
09/25/08 12:34 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
There's 2 different versions of the "245" port. a Std 245, & a Raised Port 245.... the RP head is identical in every way except they take about .250" out of the roof of the port. I would'nt use the RP on a 408, unless it was a methanol engine.
Both are designed to be ran with 2.14 or 2.15 valves.
The RP port can only be put into newer raised valve cover rail castings.
I posted Dyno #'s off a 245 non RP head motor that was hampered by a 2.1 valve (was forced into running this) about a month ago. Those were out of box untouched heads except a VJ. There is more flow to be found with a little hand work, but you can make substantial power with their OOB ports.
I've now gotten to see several sets of ICH CNC heads off of running engines & the chamber burn pattern is exceptional on them. Many complain about how BIG the CNC chamber is, but I'll take killer burn every time over a head with smaller less efficient chamber.
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125963
09/25/08 01:41 PM
09/25/08 01:41 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This is a keeper
Re: Indy's CNC ported 360-1 heads [Re: DavidDean] #125964
09/25/08 01:54 PM
09/25/08 01:54 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
It's funny I just had another new set of 245RP's come in the door UPS in between these posts....
Port entrance is 1.375" W X 2.40" Tall.... that's a big b....
369W7's set have been modified port wise, so I think I'll throw a valve in these new virgin RP's & CC a runner to see what they really are out of box. I know it's bigger than 245.
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125965
09/25/08 02:01 PM
09/25/08 02:01 PM
Mcallen, TX
Mcallen, TX
any difrence?????
Re: Indy's CNC ported 360-1 heads [Re: SB449VALIANT] #125966
09/25/08 02:11 PM
09/25/08 02:11 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Guess they're not bigger than 245 stock....
the RP245 I just measured with 2.15 Ferrea Comp Plus valve 245.5 CC...
The std port height "245" head must be smaller than 245.
I've only had 2 sets of those here & never measured them volume wise.
369's Modified set are 254 CC.
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125967
09/25/08 03:35 PM
09/25/08 03:35 PM
South Carolina
mopar addict
mopar addict
South Carolina
So which ones should I go with. The motor is a 408 now but I may go larger down the road. Im looking for max power. I run this car in a stock suspension 28 x10.5 tire class and run 2 kits (400 hp total) Can they be ordered with the bigger valves? Im running a 4.035 bore now, just wondering if bigger valves will fit. The pistons are custom Ross domes. Im ordering just the assembled heads, I already have T&D rockers on the heads I have now and my friend thats buying my heads already has the Indy rockers to go on them. Im looking for max power. My motor makes peak power now at 7600 rpm's. Made 530 rwhp through a Dana 60 and ran 6.30's @ 107 through a glide in a 3200 lb car with driver. My mustang that the motor is in now runs 6.40's @ 109 in the heat of Summer with only a 3.73 gear and a tight converter. Its 2940 with driver.
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125968
09/25/08 04:23 PM
09/25/08 04:23 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
For "Max power" & something that may be upgraded CID wise in future, buy the RP's & be done with it. The N20 will also eat up runner volume just like methanol does.
They come from ICH with 2.14" valves. They will be fine as far as hitting anything with the 4.035 bore. (won't be close)
Whether they will clear your custom Ross pistons, I have no idea, but if they were designed for the ICH head with the 2.10 valve I would think they put enough radial clearance in them to be ok with the 2.14. Call them with your custom order # & I'm sure they can tell you for sure.
You have alot of cam, & are spraying, the RP head should be fine. Just be aware there is very very little material at the top of the port for the intake to seal on.. if you try to reuse your current ICH intake & you'll have to make custom intake gaskets. We buy Raw ICH manifolds & surface them ourself to leave maximum width on manifold so it sits as high as possible on the RP head.
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125969
09/25/08 04:48 PM
09/25/08 04:48 PM
South Carolina
mopar addict
mopar addict
South Carolina
Ryan, do you sell gaskets that will work?
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125970
09/25/08 05:07 PM
09/25/08 05:07 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We sell a lot of the basic and CNC kits from Indy.As far as anything modified or exotic,RyanJ is the small block expert
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125971
09/26/08 01:51 PM
09/26/08 01:51 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Nobody makes a gasket that fits....
INDY won't make one, I asked Russ at Carlisle & he said not enough demand.
So gotta buy blank Fel Pro material & get out razor blade & make your own.
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125972
09/26/08 01:57 PM
09/26/08 01:57 PM
SoCal
Brian Hafliger Offline
SoCal
If you have a gasket cut like you want, I can get SCE to make it. They'll want an order of 20 or 30, but they will make it, and whatever thickness you like. I have them doing copper embossed W2 exhaust, regular exhaust in both round and square, and they already make very nice W2 intake gaskets in 3 different thicknesses that fit Indy's cnc -2 head with room to spare!
Brian
Brian Hafliger
Re: Indy's CNC ported 360-1 heads [Re: RyanJ] #125973
09/26/08 05:00 PM
09/26/08 05:00 PM
South Carolina
mopar addict
mopar addict
South Carolina
Im just wondering if there will be enough of a power difference between the regular 245cc cnc heads and the raised port ones to make it worth the extra trouble on my combo?
Re: Indy's CNC ported 360-1 heads [Re: Brian Hafliger] #125974
09/26/08 05:05 PM
09/26/08 05:05 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
You'd think I'd be getting used to this abuse.
Damn! I dropped my change.............
Re: Indy's CNC ported 360-1 heads [Re: a408swinger] #125975
09/26/08 05:41 PM
09/26/08 05:41 PM
Mcallen, TX
Mcallen, TX
What about trying to get in there some other type of intake? mybee some w8 or w9 MP intake or perhaps going to a chevy intake, i know i few guys are using the w8 intake on GM motors!! ryan?
