Re: please help me with my temp problem
[Re: president61]
#1259538
06/30/12 05:36 AM
06/30/12 05:36 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi may be your distributor / timing rate . what is your inital timing and what intake carb an do you have headers ??
[Re: calrobb2000]
#1259539
06/30/12 05:50 AM
06/30/12 05:50 AM
Posts: 1,044 minnesota
president61
minnesota
12 degrees mopar performance M-1 Single plane, 750 holley dbl pumper headers are coated hooker comp
[Re: 79powerwagon]
#1259542
06/30/12 11:29 AM
06/30/12 11:29 AM
Posts: 905 SD
zrxkawboy
SD
Radiator known to be clean? Fan shroud?
It's Swifty! Swifty, you toad sucker!
[Re: president61]
#1259545
06/30/12 01:26 PM
06/30/12 01:26 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
TOTAL timing is what you're looking for. 12* would be the initial, but if your using a stock distributor, and pushing the initial to 12*, you could be up over 40* total, which could cause it to run hot. Find out what your total is, or just back the initial down to about 6 or 8 and see if it affects the heat issue. If not, then you have eliminated timing.
[Re: RapidRobert]
#1259549
07/01/12 01:54 AM
07/01/12 01:54 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
That sounds like a flow issue to me.
210 is OK, but it's a problem warning. Shouldn't be that hot if things are up to snuff.
I want my fair share
[Re: president61]
#1259550
07/02/12 12:28 AM
07/02/12 12:28 AM
calrobb2000
s. e. pa.
hi yes by all means you should have a spring in the lower one and a knowen good fan clutch . your timing curve may need recalabrated . move your timing up to 16 inital and make dist top out at about 34-36 max . what is your app cranking comp psi ? hi stall convertor can also add heat , use a big trany cooler in the air streem !
[Re: president61]
#1259551
07/04/12 07:16 AM
07/04/12 07:16 AM
Posts: 409 Lexington NC
twinscrew698
Lexington NC
thanks everyone. i'm going to check timing and probably pull my rad and give it a thorough cleaning. i need to put that bottom air dam on too. i just have to make a seal since nobody repos them
That will really improve to lower your temp! Some people have thrown these away in the past and now looking for em!
[Re: furyous3]
#1259553
07/06/12 08:38 AM
07/06/12 08:38 AM
Posts: 1,513 AZ
Mike P
AZ
All of the thermostatically controlled fan clutches (the ones with the spring on the front side) I have gotten in the last several years have been factory set to lock up at 210 degrees. So basically on hot days out here that’s where my cars run (but I’ve never had one go over that as long as the clutch was good).
On a side note, if the spring on the front of the clutch is tightened (usually ½ a turn at a time), it will lower the temperature the clutch locks up).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
