what do you use to clean vinyl before you dye it? #1258555
06/27/12 10:17 PM
06/27/12 10:17 PM
Endicott, NY
bnichols Offline OP
bnichols  Offline OP
Endicott, NY
can't find blue door panels for my road runner so i am thinking about painting them with vinyl paint of course, what are you guys cleaning the vinyl with before you spray it???
Re: what do you use to clean vinyl before you dye it? [Re: bnichols] #1258556
06/27/12 10:23 PM
06/27/12 10:23 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
SEM makes vinyl prep aerosol in a can..I've used it with great results
SEM Vinyl Prep
1MYTGTX
Re: what do you use to clean vinyl before you dye it? [Re: 1MYTGTX] #1258557
06/27/12 10:30 PM
06/27/12 10:30 PM
KillerCuda Offline
KillerCuda  Offline
i have also used isopropyl alcohol, (free from work!) with fantastic results. i just re-dyed my entire interior. sem makes a superior product in my opinion, i have used it with excellent results. like paint, it's all in the prep for long lasting results........
Re: what do you use to clean vinyl before you dye it? [Re: KillerCuda] #1258558
06/27/12 11:13 PM
06/27/12 11:13 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I changed my interior from pearl white to landau black with SEMs products.
I don't think vinyl prep is supposed to be used as the main "cleaner". It is prep to get any final oil, residues, etc. right before applying color.
I first scrubbed the heck out of everything with a nylon brush and Crud Cutter (Lowe's I think...). I did this multiple times then let dry really well on a hot day in the sun.
When setting everything up to dye, I used the vinyl-prep in the spray bomb. Spray it on, then wipe it off with a damp cloth and let air dry.
After that, went at everything with landau black until covered. Don't get carried away, it goes on very thin. Many light coats is key.
I finally hit everything with two coats of the low luster clear coat.
The stuff is very forgiving. It ran on me a few times (was not being careful in a rush) and I just wiped the run and sprayed back over it. It blends great.
My door panels wrinkled on me and I freaked. It must have been a chemical reaction, because they tightened back up by the next day.
Prep, prep, and more prep. Pick a low humidity day, etc. just like when spraying paint.
383, Hemi 4-Speed, AlterKtion, D60
Re: what do you use to clean vinyl before you dye it? [Re: Crazy68Dart] #1258559
06/27/12 11:57 PM
06/27/12 11:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used rubbing alcohol with nice results.
