Stone shield 68 b body #1258191
06/27/12 10:05 AM
06/27/12 10:05 AM
mn.
P
prairiechicken1 Offline OP
P
mn.
I scored a stone shield and am asking what color should it be from factory? Also what is the proper hardware to use to install? Thanks in advance for the help!
Re: Stone shield 68 b body [Re: prairiechicken1] #1258192
06/27/12 10:57 AM
06/27/12 10:57 AM
PA
BTTG Offline
BTTG  Offline
PA
accurate for 69 for sure and I think 68 is the same
shield is black... hardware is -- 1/4-20 x 5/8", 7/16" Hex, 1/2" Conical bolts with H head marking (similar to AMK part #B-12760 ...except AMK only has anchor head marking not teh correct H) -- 1/4-20 CONS nuts/washer (similar to AMK part B-11480).... hardware is all phosphate
http://www.amkproducts.com/
look under bulk items tab
Re: Stone shield 68 b body [Re: prairiechicken1] #1258193
06/27/12 11:15 AM
06/27/12 11:15 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
both of my '68 B-bodies had black painted stone shields...hardware color but I'm sure it is as stated
Re: Stone shield 68 b body [Re: A12] #1258194
06/27/12 12:33 PM
06/27/12 12:33 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Excuse my ignorance, but I don't think I have ever seen a "stone shield".
Anybody have a photo of one?
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Stone shield 68 b body [Re: Chi_Town_Runner] #1258195
06/27/12 12:39 PM
06/27/12 12:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
It's the sheet metal piece that goes between the front bumper and the bottom radiator support to keep debris (stones, rocks, etc.) from damaging the radiator...I'll look for a photo
Re: Stone shield 68 b body [Re: A12] #1258196
06/27/12 12:45 PM
06/27/12 12:45 PM
O.K
Now I understand. I thought it was some type of additional sheet metal piece that affixed somwhere to the outside of the front of the car.
Thanks for the education on correct terminology.
Frank
Re: Stone shield 68 b body [Re: Chi_Town_Runner] #1258197
06/27/12 02:07 PM
06/27/12 02:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
More commonly called a gravel guard behind the ft bumper to protect the radiator.
as far as fasteners, I agree with the bolt, not 100% sure about the nut being dark phosphate though.
I remember seeing a picture of a low mileage car the captive washer nuts were yellow zinc
Re: Stone shield 68 b body [Re: gtx6970] #1258198
06/27/12 02:26 PM
06/27/12 02:26 PM
PA
BTTG Offline
BTTG  Offline
PA
CONS nut may not be phosphate, but the dodge fasteners manual lists it as such......
anyone else recall seeing a survivor???
Re: Stone shield 68 b body [Re: BTTG] #1258199
06/27/12 02:32 PM
06/27/12 02:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I have a couple of photos of the bolts on the '69 Hemi road runner and the '69 383 (A/C) Super Bee survivors but not here....and my '69 GTX should have the original fasteners too so it's photo time later
Re: Stone shield 68 b body [Re: BTTG] #1258200
06/27/12 05:40 PM
06/27/12 05:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Kevin,
Said guide also states the voltage regulator bolts were phosphate.
And i'm not knocking that manual.
I have them and do refer to them from time to time,
But
Use it for exactly what is was intended to be ----- a guide
