Dumb Question ignition switch
#1257592
06/26/12 09:41 AM
06/26/12 09:41 AM
Posts: 1,559 Michigan
Kiddart
How do you check an ignition switch to see if its bad or not??
Thank you Kiddart
Re: Dumb Question ignition switch
[Re: Kiddart]
#1257593
06/26/12 12:58 PM
06/26/12 12:58 PM
RapidRobert
You could check continuity with an ohmmeter between the terminals in the different key positions
[Re: RapidRobert]
#1257594
06/26/12 01:28 PM
06/26/12 01:28 PM
Kiddart
How about a test light grounded to column and doing checking the positions?? I have a feeling that power is not going thru the switch.
Thank you Kiddart
[Re: Kiddart]
#1257595
06/26/12 01:40 PM
06/26/12 01:40 PM
RapidRobert
yes that'd work. What circuit are you having a problem with?
[Re: RapidRobert]
#1257596
06/26/12 01:46 PM
06/26/12 01:46 PM
Kiddart
The starting circuit, I thought is was the netural safety but its not. I turn to aux just before the start and the fuel pump is on then go to start and it seems to lose power. I am dumbfounded its killing me.
Thank you Kiddart
[Re: Kiddart]
#1257597
06/26/12 04:32 PM
06/26/12 04:32 PM
RapidRobert
It will not crank? If not see if the yellow "ign" wire out to the starter solenoid is hot while someone holds the key to start. If not, seperate the bulkhead & see if there's a bad connection on that circuit on those 2 male/female brass terminals. (www.mymopar.com has the colors/locations). If the bulkhead is good then see if the "st" terminal on the back of the ign switch is hot when you hold it to start. If the switch is in the column seperate the dangling connector & see if the start wire going out to the starter relay has continuity with the 12V power in wire when the key is held to start.
[Re: RapidRobert]
#1257600
06/26/12 05:26 PM
06/26/12 05:26 PM
Kiddart
its weird because in november when I pulled the motor and trans everyrhing was fine, I can start the car with a screwdriver on the starter re-lay. it has to be something stupid. thanks for the info. I will try it and keep you guys posted.
Thank you Kiddart
