/6 exhaust manifold cracked/ how to repair?or replace? #1257290
06/25/12 09:15 PM
06/25/12 09:15 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
My slant six exhaust manifold has a crack and now an exhaust leak. I am guessing there is no way to weld it? And then I guess I have to find a replacement? Any other way to fix these?
RUMBLON
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257291
06/25/12 09:34 PM
06/25/12 09:34 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Sure. They can be welded. You need to find a good shop the specializes in cast iron welding.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: Steve340] #1257292
06/25/12 09:37 PM
06/25/12 09:37 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Rock auto
Guessed the application...
1975 DODGE D100 PICKUP 3.7L 225cid L6 : Exhaust : Exhaust Manifold DORMAN Part # 674232 Hardware: 2 Studs, 2 Nuts, 1 Heat Riser Spring; Gaskets: 1 Manifold & 1 Flange
Includes Gaskets and Hardware (where required)
$277.79
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257293
06/25/12 10:15 PM
06/25/12 10:15 PM
Alberta
rustbuckett68 Offline
Alberta
When you replace it, 10 ft.lbs. on the fasteners. This allows for thermal expansion, as in it slides around. If its over tightened, no movement, and it will crack. Check your FSM.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RodStRace] #1257294
06/26/12 12:01 AM
06/26/12 12:01 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Rock auto
$277.79
John, I know you are made of cash but im into this whole rig for $300.00. There is no way in heck I am paying another three bills for an exhaust manifold. And I did look at that and saw the price. I am sure I can look locally and find one, just was hoping it could be fixed easy.
dave
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257295
06/26/12 07:32 AM
06/26/12 07:32 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
You can try to fix it, but it will crack again.
I get a lot of Slants given to me, and probably 2/3 or them have the manifold cracked, usually right next to where the center dump is, between 4 and 5. Some of them are broken in half.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: slantzilla] #1257296
06/26/12 10:03 AM
06/26/12 10:03 AM
michigan woods
imfixinmopars426 Offline
michigan woods
i bought new
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257297
06/26/12 02:55 PM
06/26/12 02:55 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
dave
Yeah, Dave I'm rollin' in it.
On some stuff you just gotta spend the money. I've driven my 69 van with an exhaust leak when cold the entire time I've owned it. I've got a 2bbl carb,intake and exhaust to swap on, just haven't done it yet.
When it is time to fix it, I'd go with a good used or new. I'd hate to put in all the time and effort to get it all installed properly, then have to do it again.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RodStRace] #1257298
06/26/12 06:33 PM
06/26/12 06:33 PM
Park Forest, IL
Park Forest, IL
I rarely get one anymore that is good. They normally get stripped off if they are good because people know that the only thing worth any money on a Slant is the manifolds.
Carbs are always a crap shoot too because most of them were junk when they were new.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257299
06/26/12 07:11 PM
06/26/12 07:11 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
RUMBLON
Local guy here in Yakima welds cast iron all the time
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: dart4forte] #1257300
06/26/12 07:33 PM
06/26/12 07:33 PM
Park Forest, IL
Park Forest, IL
Welding cast is not the issue. The shape of the manifold and the way it mounts are what keep cracking it. Also, after being welded on they need to be surface milled on the port side to make them flat again. By the time you do all that you're in new manifold money anyway.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: slantzilla] #1257301
06/26/12 07:44 PM
06/26/12 07:44 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Every cracked /6 and early 273 DS manifold I've seen is missing the brace that gets tossed when the starter is changed.
Re: /6 exhaust manifold cracked/ how to repair?or replace? [Re: RUMBLON] #1257302
06/26/12 08:35 PM
06/26/12 08:35 PM
hickory nc USA
skyhawk61 Offline
skyhawk61  Offline
hickory nc USA
I don't know where your manifold crack is located, but you might try to patch it with Rutland furnace cement, available for less than 5 bucks at places like Home Depot. I used it to patch the cast iron elbow to exhaust manifold joint--elbow provides manifold heat to the carbs on the ram tubes on a Chrysler 300G with a 413. Sealed the crack, and after 2 years there's still no exhaust leak. The guy who told me about this trick also said that if you tried to use it as a "gasket" between two surfaces, you would have to use brute force or a torch to break the seal. Sounded good enough for me.This stuff is rated up to 2000 degrees; It might not work in your application but it never hurts to try the cheap way first.
