destroyed another bb-powerglide flexpate again ideas?? #1257003
06/25/12 12:19 PM
06/25/12 12:19 PM
ok
mopdragster Offline OP
ok
Well threw the ring gear off another 8 bolt flexplate for powerglide friday at tulsa divional race. broke the starter and cut a groove in the ATI bellhousing and threw it through the side of the car. So that makes 3 JW's and 2 TCI's. I am looking for input on this problem am probably going to order a new billet miezere flexplate. I have had this problem for several years through different motors and cars so I think it is a flexplate runout issue cause it always breaks the ring gear off. Anybody else have this trouble?
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257004
06/25/12 12:33 PM
06/25/12 12:33 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've been using the JW deal for 12 years with no problems. I would suggest to have somebody chuck the flywheel that broke on a brake lathe. Be sure that's what the problem is. I would also index your JW bell housing bolted to the motor with a dial indicator and be sure your dowels are lined up correctly. Good luck.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257005
06/25/12 12:35 PM
06/25/12 12:35 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
had TCI toss a hunk of the gear when standing next to the car. it broke my foot in 6 places.
that one did not have enough weld when inspected.otherwise 10 years no problems with JW. now have a billet on my big motor
home of the
Sox and Martin Hemi Duster
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: HEMIFRED] #1257006
06/25/12 12:38 PM
06/25/12 12:38 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: HEMIFRED] #1257007
06/25/12 12:55 PM
06/25/12 12:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I lost a chunk of a TCI last year at the final divisional race of the year. About the size of the onne Fred posted. Looks just like the one he posted. It was a TCI. Never had an issues with a JW. I woudl check the bell to make sure it is correctly installed as well.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: Al_Alguire] #1257008
06/25/12 01:22 PM
06/25/12 01:22 PM
sg66mopar Offline
sg66mopar  Offline
Does it look like the ring gear is breaking first, or the weld letting go causing the ring gear to break?
If you see any rust on the ends of the gear where it broke that tells you the gear was broken first. Maybe too much stress on the gear from the starter?
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: sg66mopar] #1257009
06/25/12 01:40 PM
06/25/12 01:40 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Never broke a ring on my two JW wheels. That is not saying it couldn't happen next time it is used.
I took exception to the starter engagement and all the shims required to do it the way JW instructed. Ended up using a 1/4" midplate to allow the trans to be further back in the car. Then I made another flywheel adapter for both 6 and 8 bolt cranks sense I had both. These flywheel adapters I made 1/4" thicker than the one from JW. I was able to get rid of 1/4" inch worth of starter shims. I now have a one peice solid shim for the starter. Just for info I still have the nose spacer on the starter but it is snug in the bell.
Don't know if this makes any difference whatsoever in keeping the starter ring on the gear. Another issue.. I had two ultrabells one had the bolt pattern right for the starter. The other one cocks the starter and breaks the nose on the starter. Had to weld the hole up and relocate, JW said there couldn't possibly be anything wrong because it was done on a CNC. BS if the bell slips in the jig it gets off. Stuff happens.
Might want to try another bell.
Leon
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: sg66mopar] #1257010
06/25/12 01:40 PM
06/25/12 01:40 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho some of these parts are of questionable construction, from what i've seen ATI stuff looks better. that said i would think breaking five of them is a flag, are you having problems with the engine sneezing or hard starting/cranking?
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: jamesc] #1257011
06/25/12 02:07 PM
06/25/12 02:07 PM
PA
moparacer Offline
moparacer  Offline
PA
Put an ATI adapter and plate on it and forget about it....
I have ran glides behind small blocks and big blocks for 20 years and never, not once has one failed.
Just have to make sure the converter pilot and clearance spacing is correct.
I am using it with a ultrabell behind a big block.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: jamesc] #1257012
06/25/12 02:11 PM
06/25/12 02:11 PM
oh
julian2007 Offline
julian2007  Offline
oh
12 volt or 16 volt battery? how much compression? if you broke a started and flex plate I would say you are low on battery.If its bucking the starter you will brake a fly wheel and the starter its just a matter of time. if you have a 12 volt system go to a 16 volt and problem fixed.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: julian2007] #1257013
06/25/12 02:32 PM
06/25/12 02:32 PM
ok
ok
thanks for the replies. it looks like the one fred posted. It only has 50-75 runs on this one. I have had it on different blocks and adapter midplates and still same problem. I run a gm bellhousing ATI trans case not an ultrabell. I think it is a runout problem when they weld the ring gear on.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257014
06/25/12 03:54 PM
06/25/12 03:54 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
There are a few big name outlaw and pro-mod types running these.
http://www.meziere.com/t-part_search.aspx
that is where mine is coming from.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopartony] #1257015
06/25/12 05:09 PM
06/25/12 05:09 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have never been able to use any brand out of the box. Everyone took some typer of change in spacers to get starter correct. Some even use the flywheel first against trhe crank then the converter hub adapter. Others do that in reverse. each needs different spacing plus the installers often reverse the parts as instructed. The only flywheel starter problems I have had were from using a timing retard MSD box. Hemi motor do not like to start at 10 degress advance
home of the
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopartony] #1257016
06/25/12 05:11 PM
06/25/12 05:11 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
JW wheel and forget about it. 4340 plate laser cut and the ring gears has small stitch welds. Geat piece for a Mopar to a GM trany.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: Biginchmopar] #1257017
06/25/12 05:27 PM
06/25/12 05:27 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run a JW Bell no problem breaking it but was breaking starters switch to a 16 volt solved problem.
PS take a screw driver and push your starter pinion up into the flex plate,make sure its going in straight and the proper distance into the starter ring.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: Biginchmopar] #1257018
06/25/12 05:31 PM
06/25/12 05:31 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
WOW---i just had the same thing happen to mine fri night--same pix as freds.TCI 149182 B1 motor w/PG--i've had it in the car 3 years,it broke a 4" sec of teeth off,between the welds.ordered a new one.
i run a 16 volt sys.it does "buck" every once in a while.
that happening--kept me from racing sat.
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: ROSSIO] #1257019
06/25/12 05:40 PM
06/25/12 05:40 PM
ok
ok
mine is the same as your rossio. 16 volts starts at 25 degrees 36 total never kicks back with 16v on gas. Used to kick back with the tunnel ram I blamed that on the last 3 flywheels. this one has never been kicked back against once. I'll never buy another part from jw. I have 3 broken "wheels" and the guy I borrowed one from to finish the race had 2 in his trailer. I am gonna order a meizere and try that. It has no welds and is machined from a single piece of billet.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257020
06/25/12 05:57 PM
06/25/12 05:57 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
When you order it, ask for Jerry D. He helped me out and was very knowledgable.
I still need some info about my crank before I can order mine.
$500-800 for the peice. As DusterDave says, Buy once, cry once.
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: mopdragster] #1257021
06/25/12 05:59 PM
06/25/12 05:59 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
WWWWOOOOOOOO i just saw that meizere flexplate fp30608--man $483.00
my 149182 tci for $196.00 looks good for now--if it breaks again--i will buy the meizere 30608
Re: destroyed another bb-powerglide flexpate again ideas?? [Re: ROSSIO] #1257022
06/25/12 06:00 PM
06/25/12 06:00 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
my number is 149182
home of the
