front air damn 69 B body #1256719
06/24/12 09:35 PM
06/24/12 09:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I cut some .060 to make this to get some more air the radiator and its other effects.I need to strap or support the front of it but what do you think of the angle?
Re: front air damn 69 B body [Re: Clanton] #1256720
06/24/12 09:37 PM
06/24/12 09:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
frt view.
Re: front air damn 69 B body [Re: Clanton] #1256721
06/25/12 12:23 PM
06/25/12 12:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Is your car running hot? looks fine, maybe paint it satin black
Coming soon!!!!
Re: front air damn 69 B body [Re: Clanton] #1256722
06/25/12 04:15 PM
06/25/12 04:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
1. Angle is not very important to begin with
2. I would however gone a lot wider, and likely get the same end result, and slightly shallower
Re: front air damn 69 B body [Re: jcc] #1256723
06/25/12 07:30 PM
06/25/12 07:30 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I vote for removing it and fixing the cooling system.
Re: front air damn 69 B body [Re: Clanton] #1256724
06/25/12 07:58 PM
06/25/12 07:58 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I say put a dust pan on both sides... Seriously, fix the cooling system and if you still feel like you need one of these, then run it all the way across and run it under the radiator support so it will act to create a vacuum for the radiator to hopefullypull more air thru it. the whole front end on the 68 B body is open,so how much more air do you really need. Figure out what is making it over heat now and fix that first. I don't think what you have in the picture will be much help if any.
Old Geezer Racing
Re: front air damn 69 B body [Re: SCATPACK 1] #1256725
06/25/12 09:50 PM
06/25/12 09:50 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
well what i put on is like what was used in nascar back in the day on a B body.What i have feeds direct to the rad and is from frame rail to rail so any wider and it takes air from the wheel well[not a bvad thing].I was thinking of painting it black as long as the aluminum is all scratched.
Re: front air damn 69 B body [Re: Clanton] #1256726
06/25/12 10:59 PM
06/25/12 10:59 PM
my own world
theraif Offline
theraif  Offline
my own world
make it little longer and put a brace in the middle so next time your at the track your get alot of looks
Re: front air damn 69 B body [Re: theraif] #1256727
06/25/12 11:08 PM
06/25/12 11:08 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Re: front air damn 69 B body [Re: Clanton] #1256728
06/26/12 02:18 PM
06/26/12 02:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
is it for looks or do you need more coolong? the reason old NASCARs had the dam is because they blocked off some of the grill for areodynamics.
Re: front air damn 69 B body [Re: Mr.Yuck] #1256729
06/26/12 02:42 PM
06/26/12 02:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am doing it for cooling.
Re: front air damn 69 B body [Re: Clanton] #1256730
06/26/12 02:54 PM
06/26/12 02:54 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I take it your missing this part that helps force the grill air to go through the radiator. It bolts up between the bumper and radiator support https://www.autometaldirect.com/store/pr...er-Shield-Lower
1969 Hemi Roadrunner 2nd owner
Re: front air damn 69 B body [Re: 69hemibeep] #1256731
06/26/12 03:02 PM
06/26/12 03:02 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
NO i have that!I need to seal the hood to the rad to help the air also.
