Rack and pinion steering problem! #1256692
06/24/12 08:23 PM
06/24/12 08:23 PM
Illinois USA
justnuts40 Offline OP
Illinois USA
I posted before that I have a 37 Dodge truck street rod with a 88 Dakota front end. The rack steering is new with the factory pump. The power steering is the same feel if truck is running or not. Any ideas what my problem could be?
Thanks for the post, Tony
etony58@gmail.com
Re: Rack and pinion steering problem! [Re: justnuts40] #1256693
06/24/12 09:04 PM
06/24/12 09:04 PM
Ohio
Todd Offline
Todd  Offline
Ohio
So is the pump new also?
Sounds like the pump isn't making any pressure.
Re: Rack and pinion steering problem! [Re: Todd] #1256694
06/25/12 09:52 PM
06/25/12 09:52 PM
Illinois USA
Illinois USA
The pump is 1988. Worked when it was in the downer Dakota. How do I test the pump? Need some help!
Thanks, Tony
