69 dart grill block off et,mph improvement??s #1256645
06/24/12 07:23 PM
06/24/12 07:23 PM
oregon
greendart408 Offline OP
oregon
I have a 69 dart that goes 138-139 plus. I am wanting to block the grill off with some plexiglas for a hopeful et, mph improvement. Does anyone that has a 67-69 dart have any real world experience with this around my speeds?? Thanks
Re: 69 dart grill block off et,mph improvement??s [Re: greendart408] #1256646
06/24/12 07:32 PM
06/24/12 07:32 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I go 175 not blocked off.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 69 dart grill block off et,mph improvement??s [Re: bigtimeauto] #1256647
06/24/12 07:51 PM
06/24/12 07:51 PM
oregon
oregon
So in your opinion there would be no improvement? ?
Re: 69 dart grill block off et,mph improvement??s [Re: greendart408] #1256648
06/24/12 08:09 PM
06/24/12 08:09 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
With the way the stock hood overhangs and how high the cars sit probably your not much. I am going to put a lower air dam on mine as i think that might do something
Re: 69 dart grill block off et,mph improvement??s [Re: greendart408] #1256649
06/25/12 05:14 AM
06/25/12 05:14 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
It would be very easy to answer that for yourself, just cut you a cardboard template to cover the entire grille, make a pass without it and then duct tape the template in place for one run and you'll have your answer.
Re: 69 dart grill block off et,mph improvement??s [Re: StrokerPost] #1256650
06/25/12 10:51 AM
06/25/12 10:51 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Cardboard is not strong enough. Use something that won't give. I bought a hemi dart from a guy in 1977. He ran SS and M/P with it. When he ran MP he had a clear piece of plexiglass behind the grill.
2011 Drag Pak Challenger
Re: 69 dart grill block off et,mph improvement??s [Re: rickseeman] #1256651
06/25/12 12:18 PM
06/25/12 12:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
i'm making a set of plexi-glass inserts for my grill. I'd think and it was pposted here a while ago that if you are going over 100 in the 1/4 blocking off the grill helps. I'm also going to run a 69 SS chin spoiler to keep the air clean under the car. It's worth a try.
Coming soon!!!!
Re: 69 dart grill block off et,mph improvement??s [Re: Mr.Yuck] #1256652
06/26/12 01:53 AM
06/26/12 01:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
no changes to the motor, i went from 139 mph max trap to 142 mph from removing the 6 pak n grille & installing a cowl n flat panel.
before...
after....
ET went from 9.57 best to 9.42 best. run lots of 9.4's last season, the season before was a lot of low 9.6's
Re: 69 dart grill block off et,mph improvement??s [Re: rebel] #1256653
06/26/12 05:40 PM
06/26/12 05:40 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
COOL CAR rebel.... I like it!
Re: 69 dart grill block off et,mph improvement??s [Re: 70blackfish] #1256654
06/27/12 03:25 AM
06/27/12 03:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Re: 69 dart grill block off et,mph improvement??s [Re: rebel] #1256655
06/27/12 05:18 AM
06/27/12 05:18 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
ive never seen your car run with out a hood, wonder if a cowl hood would help??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 69 dart grill block off et,mph improvement??s [Re: rickseeman] #1256656
06/27/12 08:29 AM
06/27/12 08:29 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Cardboard taped to the front of the grille will work absolutely fine, wheres it gonna go, its gotta grille behind it? Done it many a time on diff cars and 68 & 69 grilles are the best cuz they are so flat. He only needs one run WITH the cardboard on it.
Re: 69 dart grill block off et,mph improvement??s [Re: StrokerPost] #1256657
06/27/12 03:59 PM
06/27/12 03:59 PM
oregon
oregon
I will try the cardboard for kicks and see what happens. If I have positive results I will take the time and make a nice plexiglas cover. Know anyone that might want a mint new glasstek hemi hood.....lol!
Re: 69 dart grill block off et,mph improvement??s [Re: greendart408] #1256658
06/27/12 07:40 PM
06/27/12 07:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Report back with your results.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
