Re: 69 dart grill block off et,mph improvement??s
[Re: bigtimeauto]
#1256647
06/24/12 07:51 PM
06/24/12 07:51 PM
Posts: 1,073 oregon
greendart408
oregon
I go 175 not blocked off.
So in your opinion there would be no improvement? ?
[Re: greendart408]
#1256648
06/24/12 08:09 PM
06/24/12 08:09 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
With the way the stock hood overhangs and how high the cars sit probably your not much. I am going to put a lower air dam on mine as i think that might do something
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: greendart408]
#1256649
06/25/12 05:14 AM
06/25/12 05:14 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
I have a 69 dart that goes 138-139 plus. I am wanting to block the grill off with some plexiglas for a hopeful et, mph improvement. Does anyone that has a 67-69 dart have any real world experience with this around my speeds?? Thanks
It would be very easy to answer that for yourself, just cut you a cardboard template to cover the entire grille, make a pass without it and then duct tape the template in place for one run and you'll have your answer.
[Re: StrokerPost]
#1256650
06/25/12 10:51 AM
06/25/12 10:51 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Cardboard is not strong enough. Use something that won't give. I bought a hemi dart from a guy in 1977. He ran SS and M/P with it. When he ran MP he had a clear piece of plexiglass behind the grill.
2011 Drag Pak Challenger
[Re: Mr.Yuck]
#1256652
06/26/12 01:53 AM
06/26/12 01:53 AM
Posts: 4,647 aotearoa
rebel
aotearoa
no changes to the motor, i went from 139 mph max trap to 142 mph from removing the 6 pak n grille & installing a cowl n flat panel. before... after.... ET went from 9.57 best to 9.42 best. run lots of 9.4's last season, the season before was a lot of low 9.6's
[Re: 70blackfish]
#1256654
06/27/12 03:25 AM
06/27/12 03:25 AM
rebel
aotearoa
COOL CAR rebel.... I like it!
[Re: rickseeman]
#1256656
06/27/12 08:29 AM
06/27/12 08:29 AM
StrokerPost
Missouri
Cardboard taped to the front of the grille will work absolutely fine, wheres it gonna go, its gotta grille behind it? Done it many a time on diff cars and 68 & 69 grilles are the best cuz they are so flat. He only needs one run WITH the cardboard on it.
[Re: greendart408]
#1256658
06/27/12 07:40 PM
06/27/12 07:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Report back with your results. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
