Re: Leaf springs installed, drivers side sagging
[Re: Mad_Scientist]
#1256624
06/24/12 06:59 PM
06/24/12 06:59 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
Oops, sorry mods, meant to post this in the Q&A section.
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: Mad_Scientist]
#1256625
06/24/12 07:25 PM
06/24/12 07:25 PM
moparpollack
Lil Herman
Lil Herman
85086
Has the ride height been set and has it been aligned? The springs do settle after awhile. Where did you get the springs? Also a local shop can rearch your springs for around $100.
[Re: ahy]
#1256628
06/24/12 11:45 PM
06/24/12 11:45 PM
Mad_Scientist
Itasca, Texas
I forgot to mention that I also installed new 1" torsion bars. I just came back in from adjusting the torsion bars, and it seems to have cured most of it. I thought that the torsion bars would only affect the front end, but it made a difference in the rear as well. Thanks to everyone for their help! I'm going to let it sit a few days and see if it settles. Then I will adjust it again. Afer a week or so, then I plan to take it in and get an alignment.
[Re: Mad_Scientist]
#1256629
06/24/12 11:59 PM
06/24/12 11:59 PM
moparpollack
Lil Herman
Lil Herman
85086
Just because the sit low doesn't mean they are wore out. If they are a level spring you are ok, if they are below then you have trouble.
