Turn key it clicks real fast #1256417
06/24/12 02:09 PM
06/24/12 02:09 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
What is this starter seloniod or relay?
Re: Turn key it clicks real fast [Re: flatiron] #1256418
06/24/12 02:11 PM
06/24/12 02:11 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
what is it on?
Re: Turn key it clicks real fast [Re: flatiron] #1256419
06/24/12 02:11 PM
06/24/12 02:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like dirty battery connections or dead battery to me.
Re: Turn key it clicks real fast [Re: Challenger 1] #1256420
06/24/12 02:13 PM
06/24/12 02:13 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Its on a 74 Challenger with a SB I'll go clean the connections
Re: Turn key it clicks real fast [Re: flatiron] #1256421
06/24/12 02:14 PM
06/24/12 02:14 PM
Starter relay is making the noise. Check all connections and the charge of the battery.
Re: Turn key it clicks real fast [Re: TheBlueBeast] #1256422
06/24/12 03:30 PM
06/24/12 03:30 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Just call me stupid. Why do we sometimes look past the obvious 2 minutes with a wire brush varooom
Re: Turn key it clicks real fast [Re: flatiron] #1256423
06/24/12 03:58 PM
06/24/12 03:58 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Also a low battery can sometimes be attributed to bad connections, as the alt/gen can't always charge thru the corroded connections/battery posts. Check them at least once a year, not that I do, but we should.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Turn key it clicks real fast [Re: amxautox] #1256424
06/24/12 07:27 PM
06/24/12 07:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stupid?
Nah, how do you figure so many of us know the cure? BTDT, that's how.
Don't be the exception.
