Re: Need advice/info on a Hemi gen 3 install...
[Re: Chally426]
#1256337
06/24/12 11:12 AM
06/24/12 11:12 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There are a number of companies that make swap kits for this combo.
Rather than ask Moparts to do your research for you I suggest you look at their offerings.
Just remember, doing the swap will be more difficult than researching the swap and Moparts can't do that for you too.
[Re: Supercuda]
#1256338
06/24/12 11:24 AM
06/24/12 11:24 AM
Posts: 1,927 Columbus, Ohio
Chally426
Columbus, Ohio
Not looking for anyone to do research for me, looking for people that have done this, what there experiences are, and general cost to what they have done...Like you said, there are a lot of companies offering swaps, looking for pros and cons....and Cost from people that have actually done this...
And asking for help and advise here, is part of my research
[Re: Chally426]
#1256339
06/24/12 11:42 AM
06/24/12 11:42 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
I've never done the conversion myself, but you might want to consider using a 6.1l instead of a 6.4l. First, because the 6.4l is fairly new so the engine itself will be considerably more expensive. Second, because getting the VVT functioning properly might be difficult. Finally, the 6.1l has been done before so there is more information and parts available for the swap.
No longer taking $h!t from anyone!
[Re: DUFFMAN]
#1256340
06/24/12 11:51 AM
06/24/12 11:51 AM
Posts: 6,022 Morningside
AdventurerSport
waaaay out there in left field
Morningside
Surely someone is offering a stand-alone computer for the 6.4L VCT Hemi? I would think so by now...? Good luck on the project, please post updates after you get started! JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: Chally426]
#1256343
06/24/12 09:08 PM
06/24/12 09:08 PM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
I will, Maybe the 6.1 is the way to go...not sure...this is what Im trying to figure out. If I was to buy a used 6.1 drop out, what would I have to change for the install, oil pan?...ect....What else would I "HAVE" to have from the doner car?
I am doing a 6.1 into a b-body with factory efi. I did not try to scrape up used parts here and there (which I know can save some coin), but it will be somewhere between 8K and 20K depending on trans option you go with (which is where I spent a bunch to make sure I got what I wanted in the end)and how much do yourself and how long you can wait to find what you want. Everything with this is just like every other Mopar vs Ford vs Chevy project. The parts just plain cost more $$.
-Chad
[Re: Chally426]
#1256345
06/25/12 01:38 AM
06/25/12 01:38 AM
Posts: 1,030 ohio
67mprfan
ohio
Roger are you putting this in the convertible chally
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#1256346
06/25/12 08:14 PM
06/25/12 08:14 PM
Posts: 662 Tampa FL
hemibeep
Tampa FL
I have some info on my post titled srt 71 in members projects section. You can buy 6.4 without MDS. Hotwire auto should have wiring. you will need a ECU/controller, and have that flashed to tune. mike@ostdyno.com can also give you insight on programming. It will end up costing more than you think
[Re: 67mprfan]
#1256347
06/25/12 11:57 PM
06/25/12 11:57 PM
Chally426
Columbus, Ohio
No, I have a 71 barracuda, thinking about this option...
[Re: Chally426]
#1256348
06/26/12 07:55 AM
06/26/12 07:55 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I'm in the process of organising a retro fit 6.1 into an A body.
Obvious conversion issues are:
Mounts - TTI seem to be the favourites, although Street and Performance make them also.
Oil filter - Known to foul on the K frame - figure on running an angle adapter or a remote adapter plate.
Sump - Front hump won't clear the K Frame so you need one of the conversion sumps from Milodon, Canton or Weldtech. (Don't forget the pick up)
Alternator - From what I've seen, the low position Alternator fits OK in the E Body...you have to clearance the frame with an early A body
Accessories - If you're not running air con or PS, you'll need the Idler pulley supplied by BPE or S&P.
Headers - Again TTI are the "go to" people..but i understand the front drivers side pipe may need peening to clear the PS pump.
Trans - Can't help with an aftermarket set up - for a Small Block 904/727 there's a flex plate adapter - mancini, TTI or S&P
Cooling - you'll need an electric fan set up and a radiator with inlet/outlet on the passenger side.
If you want to go carb induction, the MSD 6-Hemi ECU with harness will work fine.
Carb manifold you can choose the Indy Modman, the MP or the XV Single planes...
Other considerations include compatible sensors for the oil and fuel gauges you are running, clearance around your steering box...(R&P?), a "by wire" pedal unit, or use the 80 mm cable Throttle Body.
Thats about all I know at this stage.....
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
