Reid case and bellhousing
#1256114
06/23/12 05:51 PM
06/23/12 05:51 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Anyone used this.....what about flywheel....anyone know if the jw wheel will work with this....JW keeps pushing the ship date back on the cases..been waiting 5 weeks now and another month was added to it from talking with jegs just now...I already had a jw bellhousing for a few years..just never used it...but I need a trans built now to get cruising.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: Reid case and bellhousing
[Re: fishy340]
#1256116
06/23/12 08:08 PM
06/23/12 08:08 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Yes the wheel will work, but you will have to play with the converter shims, mine took .113 to get the 1/8 inch pull out. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Mopar_racer_99]
#1256117
06/24/12 09:06 AM
06/24/12 09:06 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I have ran a stock case for ten years with the ultrabell. Never had any trouble with the case.
Leon
[Re: instigator]
#1256118
06/24/12 04:38 PM
06/24/12 04:38 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
You can use any 30 tooth flexplate for a glide. The difference can be made up in the torque converter.
TCI #149182 ATI #915660X Coan #COA-980062
