14x32 MT air pressure #1255818
06/23/12 12:56 AM
06/23/12 12:56 AM
Franklin Furnace, OH
moparman1954 Offline OP
Wondering what air pressure to start out at, new combo. 68 cuda, ladder bars, coil overs, glass hood, bumpers, lexan windows. 446 unported indy sr's, indy single plane, 950 proform carb, 607,610 comp solid cam, 12.5 wiseco pistons, 2" hooker fenderwells. 727 griner brake, 4500 lupo converter, delay box. 8 3/4, 5.13 gear, 14x32 MTs. 1/8 mile only
Re: 14x32 MT air pressure [Re: moparman1954] #1255819
06/23/12 01:20 AM
06/23/12 01:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the car weigh... front and back (race weight)
Re: 14x32 MT air pressure [Re: MR_P_BODY] #1255820
06/23/12 01:29 AM
06/23/12 01:29 AM
Have no idea, never been scaled. The slicks have tubes and are screwed.
Re: 14x32 MT air pressure [Re: MR_P_BODY] #1255821
06/23/12 01:43 AM
06/23/12 01:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
@2950lbs with me on board i run my 32x14S M/T's @ 8 psi. 1.32 60's 9.4@142mph 1/4's.
Re: 14x32 MT air pressure [Re: moparman1954] #1255822
06/23/12 02:00 AM
06/23/12 02:00 AM
Cab_Burge Online work
Cab_Burge  Online Work
Tubes or tubeless? If tubeless I would probally start high, say nine lbs and see what the car does, feel the tires after the first pass to see if there rough all the way across or just in the middle If rough all the way across, it may take two or three passes to get it where you can feel it good with your fingertips lightly sliding across the tire The other thing is go by the time slip, pump it up until it spins and then go down in pressure until it slows down on the 60 ft. times, best 60 ft is the best air pressure
Re: 14x32 MT air pressure [Re: Cab_Burge] #1255823
06/23/12 07:54 AM
06/23/12 07:54 AM
Guitar Jones Offline
I run 7.5 - 8.5 in mine depending on track conditions.
Re: 14x32 MT air pressure [Re: Guitar Jones] #1255824
06/23/12 09:53 AM
06/23/12 09:53 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I run the 14.5/32 soft sidewall and don't run tubes. With a 3200lbs 9.40-50 car I run anywhere from 11-12 pounds depending on the track. M/T tires don't like to wrinkle excessively and like more air pressure. The more air pressure you can run the more stable to car will be on the top end.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 14x32 MT air pressure [Re: Jacob Pitt] #1255825
06/23/12 10:06 AM
06/23/12 10:06 AM
ill
dennismopar73 Offline
ill
also not enough air will kill 60ft. and reaction times!
I could never run 7-9 #, car to unstable at the start, and wonder all over the place on the top end,
we run 12.5 in the coronet with hoosiers tubless, but we did have MT and ran the same pressure!
Re: 14x32 MT air pressure [Re: moparman1954] #1255826
06/23/12 10:08 AM
06/23/12 10:08 AM
NC
440Jim Offline
440Jim  Offline
NC
Weight is a big factor.
How hard the engine/converter/suspension hits the tires is a factor.
Rim width is a factor (12" uses less than 14")
A target range would be 9-11 psi for starters.
Re: 14x32 MT air pressure [Re: 440Jim] #1255827
06/23/12 10:50 AM
06/23/12 10:50 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my ladder bar car didn't like any thing less than 12# in M/T 14x32.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 14x32 MT air pressure [Re: dusturbd340W5] #1255828
06/23/12 10:56 AM
06/23/12 10:56 AM
PA
moparacer Offline
moparacer  Offline
PA
I ran 10-11 in the stiff wall 32X14...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 14x32 MT air pressure [Re: moparacer] #1255829
06/23/12 11:48 AM
06/23/12 11:48 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Running 8.25-8.5 in ours at 2900lbs and 10.0 ET
Re: 14x32 MT air pressure [Re: Dragula] #1255830
06/23/12 04:17 PM
06/23/12 04:17 PM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
I run between 10-11 in my 14.5x32. 3300lbs.
Re: 14x32 MT air pressure [Re: moparman1954] #1255831
06/23/12 05:58 PM
06/23/12 05:58 PM
Ohio, U.S.
73-Dart-sport Offline
Ohio, U.S.
11 3/4 #'s in our 2850 lb car. Tires don't wrinkle much. We run the most air we can without the tires spinning.
Re: 14x32 MT air pressure [Re: moparman1954] #1255832
06/23/12 06:28 PM
06/23/12 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Without knowing the weight you can start out with the
suggestions the guys have given and play with it
from there... M/T tires do like a bit more air but
being that your running tubes it will be a bit less
but its still going to be a test and see
Re: 14x32 MT air pressure [Re: MR_P_BODY] #1255833
06/23/12 07:00 PM
06/23/12 07:00 PM
Arizona
Chris'sBarracuda Offline
Arizona
Kind of like jetting..
Air them up till they spin, then back it off just a little..
Chris..
Re: 14x32 MT air pressure [Re: MR_P_BODY] #1255834
06/23/12 07:36 PM
06/23/12 07:36 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
interesting some of the claims of running 10 psi n higher. my very first set of MT 32x14's i ran at 10 psi, i found that although i still had depth dots on the sides of the slick, i was starting to see the fabric in the middle of the slick. basicly they were over inflated & wearing out at 10 psi. once i started running a lower pressure i could see more even wear across the surface. i'm running the stiff sidewall as thats the only type my local MT agent brings in to our country so it might be different to the soft sidewall. even so at 8 or sometimes 7.5 psi, my car is very stable @ the top end.
Re: 14x32 MT air pressure [Re: rebel] #1255835
06/23/12 07:48 PM
06/23/12 07:48 PM
ill
ill
Rim size,is most likely the issue, to big of burn outs! jmo,
I have a 14" but wish I had a 15" with my 14 32 w
Re: 14x32 MT air pressure [Re: dennismopar73] #1255836
06/23/12 09:31 PM
06/23/12 09:31 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
true that. 15" rims here & tend to be somewhat conservative on the burnout,
Re: 14x32 MT air pressure [Re: rebel] #1255837
06/24/12 06:01 PM
06/24/12 06:01 PM
Kissimmee Fl.
Kissimmee Fl.
My car was a ladder bar car 14x32x15 on a 14" wide rim at 10# of air the car hit the tire hard enough that it would crush the tire and the rim would be all but on the pavement and it would get a little wobbly on the big end.
with 12# of air all that went away and slicks wore very flat and even.
That was leaving on a brake at 5800.
