valve adjustment,how do you do yours? #1254778
06/20/12 11:24 PM
06/20/12 11:24 PM
Caledonia, Ohio
BigDog68Dart Offline OP
Caledonia, Ohio
Cold or Hot, by the mopar sticker,or do you have a more accurate way? what works best for you?
Re: valve adjustment,how do you do yours? [Re: BigDog68Dart] #1254779
06/20/12 11:28 PM
06/20/12 11:28 PM
North Dakota
Azzkikrcuda Online content
Azzkikrcuda  Online Content
North Dakota
Exhaust Opening Intake Closing method. I do them cold.
Re: valve adjustment,how do you do yours? [Re: Azzkikrcuda] #1254780
06/21/12 12:02 AM
06/21/12 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.... it just takes longer to do
Re: valve adjustment,how do you do yours? [Re: MR_P_BODY] #1254781
06/21/12 12:11 AM
06/21/12 12:11 AM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
Same method for me.
Re: valve adjustment,how do you do yours? [Re: gj69charger] #1254782
06/21/12 12:38 AM
06/21/12 12:38 AM
Az
Crizila Offline
Crizila  Offline
Az
Same method for me.
Me too, but the Mopar sticker also works, and it's twice as fast.
Fastest 300
Re: valve adjustment,how do you do yours? [Re: gj69charger] #1254783
06/21/12 12:38 AM
06/21/12 12:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
same here. i use a remote starter and can have all valves lashed within 20 min. start to finish. way faster than the mopar decal.
Re: valve adjustment,how do you do yours? [Re: mopar dave] #1254784
06/21/12 02:33 AM
06/21/12 02:33 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
ICE-EOI here as well. IMO it is the most accurate way to go, ensures you are on the base circle of the lobe you are adjusting. Once you get used to it, it will go quickand you just go down the line.
Re: valve adjustment,how do you do yours? [Re: Al_Alguire] #1254785
06/21/12 02:36 AM
06/21/12 02:36 AM
Arizona
Chris'sBarracuda Offline
Arizona
Chris..
Re: valve adjustment,how do you do yours? [Re: Chris'sBarracuda] #1254786
06/21/12 03:29 AM
06/21/12 03:29 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
EOIC and I have a bump button under the hood which makes it faster and easier IMO.... I set the valves using the mopar chart then went right back around using EOIC and I couldn't believe how much slop was in there vs EOIC
Mopar Performance
Re: valve adjustment,how do you do yours? [Re: moparniac] #1254787
06/21/12 08:20 AM
06/21/12 08:20 AM
tboomer Offline
tboomer  Offline
Interesting thread as I am going to go thru mine. I think tere are a few guys that prefer the MP method. That may be easier for me...
Re: valve adjustment,how do you do yours? [Re: tboomer] #1254788
06/21/12 08:31 AM
06/21/12 08:31 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Cold and I pull the plugs out so I can turn the crank by hand going through the firing order. Anal Yes
Re: valve adjustment,how do you do yours? [Re: poisondart2] #1254789
06/21/12 09:20 AM
06/21/12 09:20 AM
Guitar Jones Offline
I use the Mopar decal because with an accurately marked damper I can set the valves on the same exact spot every time. This way you can keep records and notice if something is going wrong. If you use the other method you may not be at the same spot everytime.
BTW I looked at my cam while using the Mopar method and they are indeed on the base circle and I have a fairly radical mechanical roller.
Re: valve adjustment,how do you do yours? [Re: Guitar Jones] #1254790
06/21/12 09:30 AM
06/21/12 09:30 AM
Also need to add that I set them cold initially then warm the engine. Set a couple cylinders then allow it to cool overnight. Then I go back and measure those cylinders and that is my cold lash number so I can adjust them all cold that way. Makes for less mess and no burns.
Re: valve adjustment,how do you do yours? [Re: Guitar Jones] #1254791
06/21/12 09:31 AM
06/21/12 09:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I use the mopar chart, set them cold... doesn't take long. Next time I might pull the plugs, turning it over by hand with the plugs in is a bieoutch. Is there any advantage in doing it one way over the other? I'm not really concerned about time. I figure it's a 2 beer event no matter.
Coming soon!!!!
Re: valve adjustment,how do you do yours? [Re: Mr.Yuck] #1254792
06/21/12 09:56 AM
06/21/12 09:56 AM
I think the advantage is as I stated above, you can set it accurately on the same spot everytime and keep records so you can notice any trends and spot a small problem before it becomes a big problem.
Re: valve adjustment,how do you do yours? [Re: moparniac] #1254793
06/21/12 10:08 AM
06/21/12 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On larger duration cams I tried it both ways and
found the the EOIC was more accurate as well
Re: valve adjustment,how do you do yours? [Re: MR_P_BODY] #1254794
06/21/12 10:18 AM
06/21/12 10:18 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i agree with mike. i have consistantly found loose rocker arms/lash when double checking after using the mp method. never with the eoic method.
Re: valve adjustment,how do you do yours? [Re: mopar dave] #1254795
06/21/12 12:07 PM
06/21/12 12:07 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Exhaust Opening Intake Closing.This method may take a little longer but I want mine Right.After setting a intake & exhaust on each side Hot and finding out the correct setting on Cold,from then on I set them Cold.
I have also found out on Big cams it is Best to let the exhaust valve open about 1/2 way (instead of time it starts to move)and then set the intake.
PS I have also been told by a Big Time Mopar engine builder,all you need to do is get them with in a couple of .000 either way,at the Best all you can hope to pick up is a .001 or .002 and you are a Bracket Racer so why spend the extra time!
Well I may only be a Bracket Racer, and I don't know about you but I want every thousandth I can get out of my engine.
Double PS Topics like this are why I come on Moparts. There is always a chance someone else has a better way(Better not interested in Faster)of doing things that lead to what I call Free Horse-Power!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: valve adjustment,how do you do yours? [Re: mopar dave] #1254796
06/21/12 12:07 PM
06/21/12 12:07 PM
What I've noticed is there is adjacent lobe spring pressure when using that method. With stiff springs you are probably seeing cam and/or rocker shaft deflection, not actual lash slop.
Re: valve adjustment,how do you do yours? [Re: Guitar Jones] #1254797
06/21/12 02:16 PM
06/21/12 02:16 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
IOEC here as well. I have always lashed them cold too.
