Largest core available for 22 inch radiator?? #1254212
06/20/12 07:24 AM
06/20/12 07:24 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Actually two questions for you guys. I have a 22 inch radiator (correct tank numbers for my 69 bee) that I would like to recore with the biggest available replacement core. Is a replacement with 4 rows of tubes available? Also when I recently recored an "055" radiator I had to replace the bottom tank to fit the 4 tube replacement. Is there a 22 inch bottom tank out there that a 4 tube core 22 inch core would fit?
Jt
Yeah, it's hopped up to over 160...
Re: Largest core available for 22 inch radiator?? [Re: jt4406] #1254213
06/20/12 09:58 AM
06/20/12 09:58 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
We use a 5/8" tube on a 7/16" center on that radiator if someone is looking for a max cooling setup. It keeps it 2 1/4" thick so we can use your original lower tank. Call me if your interested.
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
1.715.842.3352
bobs@glenrayradiators.com
www.restorationradiators.com
