Actually two questions for you guys. I have a 22 inch radiator (correct tank numbers for my 69 bee) that I would like to recore with the biggest available replacement core. Is a replacement with 4 rows of tubes available? Also when I recently recored an "055" radiator I had to replace the bottom tank to fit the 4 tube replacement. Is there a 22 inch bottom tank out there that a 4 tube core 22 inch core would fit?
Jt
Yeah, it's hopped up to over 160...
