The great alternator question... #125399
09/24/08 09:15 AM
09/24/08 09:15 AM
30 Rock
JS29 Offline OP
JS29  Offline OP
30 Rock
I've been read all I could find, and there are a lot of varying opinions on replacing/upgrading alternators on our old mopars. So much so, almost feel more lost than when I started.
What are the stock (amp) specs for a 70 alternator?
Would swapping out my anemic alternator with this one be worth it? All I want to do is prevent dimming lights and keep my radio powered at idle while stopped in Drive. BTW, aside from an aftermarket CD-Radio, I am not running any other non-stock electrical items (no electric fuel pump, no electrical fans, no amps, etc...)
If I did swap out with the 50amp linked above, would I need to do any rewiring as recommended with other high-amp upgrades?
Re: The great alternator question... [Re: JS29] #125400
09/24/08 10:19 AM
09/24/08 10:19 AM
AndyF Offline
AndyF  Offline
I developed the Denso swap to solve those problems. The stock Mopar alternators are very lazy at low speeds. The Denso alternator solves all the problems and it bolts on with very easy wiring mods. I switched my car over a long time ago and would never go back to a Mopar alternator.
Re: The great alternator question... [Re: AndyF] #125401
09/24/08 01:34 PM
09/24/08 01:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
lates 70s, eartliers 80s stock mopar alts gives good power...
and you have also upgrade kits option:
http://store.alternatorparts.com/daimlerchrysler.aspx
Re: The great alternator question... [Re: JS29] #125402
09/24/08 01:53 PM
09/24/08 01:53 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
To answer your question, there should be no trouble in just swapping the alternators out. Your current draw is not much different than your original Mopar. You may have doubled your radio current draw but that would going from 2 amps to 4 amps. No big deal.
Craig
Re: The great alternator question... [Re: denfireguy] #125403
09/24/08 09:42 PM
09/24/08 09:42 PM
IN
ahy Offline
ahy  Offline
IN
There are lots of upgrades... for the wiring I think its a good idea to avoid sending charging current through the bulkhead connector. Even with the stock alternator its a point of failure. A simple wire, 10 guage or heavier, from the alternator output to the starter relay with a length of fusible link included will take care of the problem. Then you can upgrade to a later model higher output Chrysler or Denso alternator with confidence. You will need to add a voltmeter to track charging system performance as the original ammeter won't work. My
Re: The great alternator question... [Re: ahy] #125404
09/25/08 10:35 AM
09/25/08 10:35 AM
30 Rock
JS29 Offline OP
JS29  Offline OP
30 Rock
Being a complete auto electrical novice, are there varying "levels" for fusible links? If so, what would be a good one to get for a 60amp alternator upgrade?
Re: The great alternator question... [Re: JS29] #125405
09/25/08 10:42 AM
09/25/08 10:42 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
http://www.allpar.com/history/mopar/electrical.html
there is a info table there about that
and as Usually, I allways will post MY link about some good upgrades
some upgrades on charging system, on a Mopar way
and a nice informative discussion about everything related here:
https://board.moparts.org/ubbthreads/showthreaded.php?Cat=0&Number=4646894&page=0
the link I posted about the upgrade is there too
Re: The great alternator question... [Re: NachoRT74] #125406
09/25/08 12:02 PM
09/25/08 12:02 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Even if you don't do away with the bulkhead pass through, you can improve things A LOT by just simply taking the lug off one stud on the AMP gauge and hooking it to the other side. That will cut the gauge out and make for a nice and neat wiring solution at the same time.
I want my fair share
Re: The great alternator question... [Re: AndyF] #125407
09/25/08 02:30 PM
09/25/08 02:30 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Mopar alternators have VERY lazy idle charging characteristics. I recently had this problem with my 5A. Power windows, seats, door locks, and a mild stereo only compounded the problem. Stepping up from the stock 60 amp to a 73 amp round-back made little to no difference.
I picked up the 60 amp Denso kit from Mancini's and remedied the issues. Charges like a new vehicle.
Re: The great alternator question... [Re: AndyF] #125408
09/25/08 04:37 PM
09/25/08 04:37 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I can vouch for that. I have Andy's 120 amp denso kit on the 440 in my 66 Coronet and the voltage is rock steady. It also sits lower which cleans up the engine compartment a bit.
Re: The great alternator question... [Re: Lefty] #125409
09/25/08 06:11 PM
09/25/08 06:11 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Another vote for the Denso, I use a 120 amp one on my small block, and it works great (after I made sure I had the right bottom pulley size, per AndyF's advice).
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: The great alternator question... [Re: JS29] #125410
09/25/08 09:15 PM
09/25/08 09:15 PM
IN
ahy Offline
ahy  Offline
IN
The guideline for fusible links is to go 2 sizes smaller than the main wire. So 10 guage main wire would take a 14 guage fusible link. Autozone and NAPA usually stock the fusible link. The 10 guage wire should be fine for an upgraded stock alternator up to 75 amps or a small Denso. Bigger than that and the main wire should be heavier - 6 or 8 guage. NAPA stocks the heavier wires.
Re: The great alternator question... [Re: ahy] #125411
09/27/08 09:36 AM
09/27/08 09:36 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I went with the 60 amp internally regulated, it was easy. Eddy heads made mine a little tight, but I was able to modify an old adjustment bracket, and make some sleeve spacers. I also have not much more that a stock electrical load. I also routed the main power feed seperate from the bulkhead connector,and wired in two relays into the head light harness to stop the main power from running through my ing. switch and dimmer switch. Very happy, NO dimming lights, I didn't change my fusible link because my alt is only the 60 amp version.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: The great alternator question... [Re: FurryStump] #125412
09/27/08 10:35 AM
09/27/08 10:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It's a good idea to upgrade the alt to a newer style that will charge more at idle. It really don't matter if you put a 300 amp alt on as it will only put out what the car needs and then the volt regulation will cut it back once the battery volts is in the 13.0 to 15.0 range. Ron
Re: The great alternator question... [Re: JS29] #125413
09/27/08 11:59 AM
09/27/08 11:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
JS29, I am in the same situation as you, no non-stock items other than a CD player. I put in a 60 amp alternator out of a 75 Dart SE slant 6 and it charges fine. At idle I don't even notice my lights dimming. I do drive the car at night lots, but always in town where there's so much ambient lighting you don't even need headlights really, so I don't even notice the lights dimming, and I idle at 600rpm in gear. They probably do dim, I just don't notice it. Then again I run stock headlights, which weren't the brightest at the best of time, but again, street lamps throw so much light that the only use headlights have to me is to alert other drivers of my car's location. Has no problem running the CD player though, that never skips a beat. Yes there are some great alternator conversions out there, but if you really don't need all that power, why go through the trouble? 60 amp alt does me just fine, the rest just adds to the charm of these old cars.
Re: The great alternator question... [Re: Lefty] #125414
09/27/08 12:52 PM
09/27/08 12:52 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I've had my denso on my big block for over 6 years. it's a 130amp out of an 02 ram van. bolted to stock big block brackets and I added a 4g wire from alt to pos stud on starter relay. I also cleaned the bulkhead connector real good and bypassed the amp gauge. best money I have ever spent on the car.
you can get cheap denso's on ebay all day long
Re: The great alternator question... [Re: Pool Fixer] #125415
09/27/08 01:17 PM
09/27/08 01:17 PM
WA 98043
thecarfarmer Offline
WA 98043
How 'bout some semi-hijacking...
I've got a couple of these alternators, one of which has a multi-rib belt. I'm interested in changing my 383 over to multi-rib when I get around to going reverse-cool w/ an SBC pump.
What years of 3.9/5.2/5.9 should I look for to steal a crank pulley?
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: The great alternator question... [Re: thecarfarmer] #125416
09/27/08 04:18 PM
09/27/08 04:18 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Any pics on a 69 and earlier small block?
Re: The great alternator question... [Re: Pool Fixer] #125417
09/27/08 04:28 PM
09/27/08 04:28 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
OK.
So you ran a new wire from the alt to the starter relay.
Did you leave the original wire hooked up as original? Or does it have to be removed for this upgrade to be effective?
And does anyone know if the Denso, or later chrysler alternator will work with my new , March brackets on my 440?
thanks
codfish
Re: The great alternator question... [Re: kick_the_reverb] #125418
09/27/08 04:57 PM
09/27/08 04:57 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Ran
have any pics of the sm blk install?
