The great alternator question...
#125399
09/24/08 09:15 AM
09/24/08 09:15 AM
Posts: 3,980 30 Rock
JS29
30 Rock
I've been read all I could find, and there are a lot of varying opinions on replacing/upgrading alternators on our old mopars. So much so, almost feel more lost than when I started. What are the stock (amp) specs for a 70 alternator? Would swapping out my anemic alternator with this one be worth it? All I want to do is prevent dimming lights and keep my radio powered at idle while stopped in Drive. BTW, aside from an aftermarket CD-Radio, I am not running any other non-stock electrical items (no electric fuel pump, no electrical fans, no amps, etc...) If I did swap out with the 50amp linked above, would I need to do any rewiring as recommended with other high-amp upgrades? Thanks
Re: The great alternator question...
[Re: JS29]
#125402
09/24/08 01:53 PM
09/24/08 01:53 PM
Posts: 1,822 Colorado
denfireguy
Colorado
To answer your question, there should be no trouble in just swapping the alternators out. Your current draw is not much different than your original Mopar. You may have doubled your radio current draw but that would going from 2 amps to 4 amps. No big deal. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: ahy]
#125404
09/25/08 10:35 AM
09/25/08 10:35 AM
JS29
30 Rock
A simple wire, 10 guage or heavier, from the alternator output to the starter relay with a length of fusible link included will take care of the problem.
Being a complete auto electrical novice, are there varying "levels" for fusible links? If so, what would be a good one to get for a 60amp alternator upgrade?
[Re: NachoRT74]
#125406
09/25/08 12:02 PM
09/25/08 12:02 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Even if you don't do away with the bulkhead pass through, you can improve things A LOT by just simply taking the lug off one stud on the AMP gauge and hooking it to the other side. That will cut the gauge out and make for a nice and neat wiring solution at the same time.
I want my fair share
[Re: AndyF]
#125408
09/25/08 04:37 PM
09/25/08 04:37 PM
Posts: 6,516 Santa Cruz, California
Lefty
I developed the Denso swap to solve those problems. The stock Mopar alternators are very lazy at low speeds. The Denso alternator solves all the problems and it bolts on with very easy wiring mods. I switched my car over a long time ago and would never go back to a Mopar alternator.
I can vouch for that. I have Andy's 120 amp denso kit on the 440 in my 66 Coronet and the voltage is rock steady. It also sits lower which cleans up the engine compartment a bit.
[Re: Lefty]
#125409
09/25/08 06:11 PM
09/25/08 06:11 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Another vote for the Denso, I use a 120 amp one on my small block, and it works great (after I made sure I had the right bottom pulley size, per AndyF's advice). Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: JS29]
#125410
09/25/08 09:15 PM
09/25/08 09:15 PM
Posts: 7,664 IN
ahy
IN
The guideline for fusible links is to go 2 sizes smaller than the main wire. So 10 guage main wire would take a 14 guage fusible link. Autozone and NAPA usually stock the fusible link. The 10 guage wire should be fine for an upgraded stock alternator up to 75 amps or a small Denso. Bigger than that and the main wire should be heavier - 6 or 8 guage. NAPA stocks the heavier wires.
[Re: FurryStump]
#125412
09/27/08 10:35 AM
09/27/08 10:35 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It's a good idea to upgrade the alt to a newer style that will charge more at idle. It really don't matter if you put a 300 amp alt on as it will only put out what the car needs and then the volt regulation will cut it back once the battery volts is in the 13.0 to 15.0 range. Ron
[Re: JS29]
#125413
09/27/08 11:59 AM
09/27/08 11:59 AM
DaytonaTurbo
Manitoba, Canada
JS29, I am in the same situation as you, no non-stock items other than a CD player. I put in a 60 amp alternator out of a 75 Dart SE slant 6 and it charges fine. At idle I don't even notice my lights dimming. I do drive the car at night lots, but always in town where there's so much ambient lighting you don't even need headlights really, so I don't even notice the lights dimming, and I idle at 600rpm in gear. They probably do dim, I just don't notice it. Then again I run stock headlights, which weren't the brightest at the best of time, but again, street lamps throw so much light that the only use headlights have to me is to alert other drivers of my car's location. Has no problem running the CD player though, that never skips a beat. Yes there are some great alternator conversions out there, but if you really don't need all that power, why go through the trouble? 60 amp alt does me just fine, the rest just adds to the charm of these old cars.
[Re: Pool Fixer]
#125415
09/27/08 01:17 PM
09/27/08 01:17 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
How 'bout some semi-hijacking...
I've got a couple of these alternators, one of which has a multi-rib belt. I'm interested in changing my 383 over to multi-rib when I get around to going reverse-cool w/ an SBC pump.
What years of 3.9/5.2/5.9 should I look for to steal a crank pulley?
-bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: Pool Fixer]
#125417
09/27/08 04:28 PM
09/27/08 04:28 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I've had my denso on my big block for over 6 years. it's a 130amp out of an 02 ram van. bolted to stock big block brackets and I added a 4g wire from alt to pos stud on starter relay. I also cleaned the bulkhead connector real good and bypassed the amp gauge. best money I have ever spent on the car.
you can get cheap denso's on ebay all day long
OK.
So you ran a new wire from the alt to the starter relay.
Did you leave the original wire hooked up as original? Or does it have to be removed for this upgrade to be effective?
And does anyone know if the Denso, or later chrysler alternator will work with my new , March brackets on my 440?
thanks codfish
[Re: kick_the_reverb]
#125418
09/27/08 04:57 PM
09/27/08 04:57 PM
Posts: 5,337 the house on the left.
cogen80
have any pics of the sm blk install?
