'06 Durango Distance to Empty Went from 384 to 303 Mi. #125350
09/24/08 12:43 AM
09/24/08 12:43 AM
Costa Mesa, California
michaelphbarnett Offline OP
Our '06 Dodge Durango 5.7 Hemi 4x4 that we ordered new has had the distance to empty (DTE) go from 389 miles down to 303 miles after a fill up. It now has about 43,000 miles on it. Anybody else experience this? It has had all the recommended service and has a new air cleaner too.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125351
09/24/08 03:01 AM
09/24/08 03:01 AM
Piscataway, NJ
moparkid1966 Offline
super gas
super gas
Piscataway, NJ
How many fuel tanks was this averaged over?
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: moparkid1966] #125352
09/24/08 06:30 AM
09/24/08 06:30 AM
IN
ahy Offline
ahy  Offline
IN
DTE is calculated on recent average fuel economy. If you were cruising at 19 MPG when the first calculation was made and later driving around town at say 14 MPG when the second was made the change in DTE would be normal.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: ahy] #125353
09/24/08 10:08 AM
09/24/08 10:08 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
it's about time for winter gas too. Notorious for lower mileage...
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: moparkid1966] #125354
09/24/08 03:32 PM
09/24/08 03:32 PM
It's the same person driving it over the same general route since new. The reason I'm asking is that I would think it would have gone up a little from new instead of going down.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125355
09/24/08 04:16 PM
09/24/08 04:16 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Don't put too much stock into what that computer says; the DTE function is a novelty at best. Hand calculate your mileage and if you see a real drop of 23% THEN get concerned.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125356
09/24/08 04:36 PM
09/24/08 04:36 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
These things may not be super accurate but they are usually pretty consistent. Poor mileage can indicate a problem. Does it idle rougher than it did or stumble at all? I had similar issues with other vehicles and once it was a bad wire and once replacing the plugs solved the problem.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: DPelletier] #125357
09/25/08 09:59 PM
09/25/08 09:59 PM
The problem is that I didn't hand calculate the mileage when it was new. I just remember the DTE being 384 miles when I'd fill it up and now the DTE is down to 303 miles.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125358
09/25/08 10:04 PM
09/25/08 10:04 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Have you tuned up yet. Hemi has standard plugs. 30K
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: SALEM1912] #125359
11/23/10 03:56 PM
11/23/10 03:56 PM
Yes, it had a tuneup.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125360
11/23/10 07:55 PM
11/23/10 07:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Did you get new tires? changing to a taller tire will knock it down
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: ademon] #125361
11/23/10 10:45 PM
11/23/10 10:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
How recent is the decline? Has it just happened the last month or so? My tow vehicle has lost 1 1/2 mpg the last few weeks. It does it every fall. Winter blend gas.
Master, again and still
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: ademon] #125362
11/07/12 10:27 PM
11/07/12 10:27 PM
it has gotten new tires from the same manufacturer, the same model and the same size. This didn't change the DTE.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: michaelphbarnett] #125363
11/08/12 03:23 AM
11/08/12 03:23 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like you're doing a bit of local city driving and the avg mpg should be lower too from when you first got it.
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: buildanother] #125364
11/08/12 03:30 AM
11/08/12 03:30 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It could be something as simple as a change in the accuracy of the fuel sender...
Re: '06 Durango Distance to Empty Went from 384 to 303 Mi. [Re: RodStRace] #125365
11/08/12 03:51 AM
11/08/12 03:51 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
This.
Mo' Farts
Moderated by "tbagger".
