Re: New Outlaw racecar arrived!
[Re: dezduster]
#1253206
06/18/12 06:22 PM
06/18/12 06:22 PM
Posts: 1,019 Finland
mafo
Finland
In a light car like that, it will be plenty fast
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1253207
06/18/12 06:40 PM
06/18/12 06:40 PM
Posts: 51 Vacaville, Ca
Kenny705K
Vacaville, Ca
Nice car man! Definitely different, very nice choice. It looks very similar to mine, except you are missing 2 doors haha. The video you linked says it's a 64, but isn't it a 65? Ours is a 65 but has a 64 grille like yours, I think it looks better that way. The body line on the front fender is usually spread apart a lot more on the 64's. How much does the car weigh? Ours is 2,500 with me in it. If you are close to the same weight, you should run in the mid 8's
[Re: Georg]
#1253212
06/18/12 08:21 PM
06/18/12 08:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Nice ride... I dont know if you have to follow NHRA rules .. but if so that padding in the cage wont fly... not NHRA certified
[Re: Kenny705K]
#1253213
06/18/12 08:45 PM
06/18/12 08:45 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
How much does the car weigh? Ours is 2,500 with me in it. If you are close to the same, 8.50s should be in the mid 8's.
Love the fender-skirts..!!
If you like drag racing, support your local track.
[Re: Kenny705K]
#1253214
06/19/12 07:06 AM
06/19/12 07:06 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
This car weighted almost same or even a bit less with iron headed bigblock motor and with almost 60lbs heavier driver. So with my R5/P7 motor and with me inside it should weight about 270-290lbs less...I quess weight comes about 2300lbs
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
[Re: jyrki]
#1253217
06/19/12 10:04 AM
06/19/12 10:04 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
LOVE IT but isnt it going to steer a little funny with those tiny front wheels?
[Re: tboomer]
#1253219
06/19/12 01:22 PM
06/19/12 01:22 PM
Posts: 70 Finland
mopar396
Finland
Nice It was great to meet you Georg in motopark!!
MOPAR OR NO CAR
[Re: Georg]
#1253220
06/19/12 02:19 PM
06/19/12 02:19 PM
Posts: 4,421 in a chair
mopartony
in a chair
That Iron headed BB is about 600 lbs, that R5 is heavier than you think. The sticker on mine says 499.5lbs I have to assume that is fully dressed and including the NASCAR carb which is really light, Titanium I think.
I would think a 100lbs lighter.
But I could be wrong. Just sayin'
[Re: mopartony]
#1253221
06/19/12 04:07 PM
06/19/12 04:07 PM
Georg
Europa, Estonia
mopartony- I cant belive that aluminium headed small block would be so heavy and weight only 100lbs less than 500cid iron headed bigblock with two carbs...But I need to weight my motor to be sure
Premium Performance
