Where do I drill the hole??? #1253180
06/18/12 04:30 PM
06/18/12 04:30 PM
London,Ontario,Canada
1962Savoy Offline OP
I just mounted a B&M shifter in my 62 Savoy and I went from a 4 speed to an automatic.The shifter is a rear cable operated and I was trying to figure out where to drill the hole in the trans hump? any ideas or pics out there???
Re: Where do I drill the hole??? [Re: 1962Savoy] #1253181
06/18/12 05:25 PM
06/18/12 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Place the shifter where you want it and if the instructions don't specify a measurement then the angle of the cable out of the shifter should locate the hole area for you.
Re: Where do I drill the hole??? [Re: stumpy] #1253182
06/18/12 09:35 PM
06/18/12 09:35 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Put it where its most comfortable but still functional.
Ride eternal, shiny and chrome
Re: Where do I drill the hole??? [Re: DirectSubjection] #1253183
06/18/12 10:33 PM
06/18/12 10:33 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If it's a rear exit will the cable go through the old 4 speed shifter hole?
Re: Where do I drill the hole??? [Re: slantzilla] #1253184
06/19/12 11:18 AM
06/19/12 11:18 AM
unfortunatly it wont go through the old hole as its forward of the shifter.I just dont want to drill any hole and find its exits out on top of the drive shaft or the exhaust.
Re: Where do I drill the hole??? [Re: 1962Savoy] #1253185
06/19/12 11:44 AM
06/19/12 11:44 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Find a good spot under the car and drill up.
Biggest thing to worry about is not getting a sharp bend in the cable.
