'Cuda battery kill switch location w/push rod #1252438
06/17/12 01:43 AM
06/17/12 01:43 AM
Arizona
Chucklehead Offline OP
Arizona
Can you post some pictures of how you mounted a battery shut off switch using a push rod to move the switch. This for a street/ strip car and was trying to find a place to mount it and where the rod exits through the rear panel. Trying to make it a clean look. Thanks.
Still Broke
Re: 'Cuda battery kill switch location w/push rod [Re: Chucklehead] #1252439
06/17/12 01:56 AM
06/17/12 01:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have a E body so I cant help with pics... BUT
make sure you put it where the safety people can see
it and get to it EASY(remember it might be YOUR life
that they might be trying to save)... plus it has
to be labeled ON OFF .... also make sure that you
have it so its PUSH in to turn it off... I have seen
them where it was set up to pull to turn off... when
the car launched it would slide the rod back and shut
it off(G-force)... just for your info
Re: 'Cuda battery kill switch location w/push rod [Re: Chucklehead] #1252440
06/17/12 08:16 AM
06/17/12 08:16 AM
London,Ontario,Canada
1962Savoy Offline
1962Savoy  Offline
its not a Cuda but I hate punching hols in good tin so I put it through the back up light
Re: 'Cuda battery kill switch location w/push rod [Re: Chucklehead] #1252441
06/17/12 09:55 AM
06/17/12 09:55 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
No rod, but the key hole position worked for mine....
Re: 'Cuda battery kill switch location w/push rod [Re: Chucklehead] #1252442
06/17/12 10:00 AM
06/17/12 10:00 AM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I would also look into installing the lokar cut off switch I can't tell you how many times you get buckled in and forget to turn rear cut off switch on, Its nice to just be able to kill everything without fumbling around.
Re: 'Cuda battery kill switch location w/push rod [Re: mokid] #1252443
06/17/12 11:37 AM
06/17/12 11:37 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Key hole here too...
Re: 'Cuda battery kill switch location w/push rod [Re: RodStRace] #1252444
06/17/12 09:08 PM
06/17/12 09:08 PM
Mo.
racerx Offline
racerx  Offline
Mo.
mine
